Newel Post Finial
We recently purchased a brownstone with a missing finial on the main staircase. After exhausting the selection at Adriatic and Dykes (we’ve bought and returned 5 finials) and striking out on the internet (also bought 2 that just don’t work) we’ve realized we need something custom made. Does anyone have a recommendation for someone who can help us turn and install a finial? We’ve reached out to John Thomas Fine Finishes a couple times with no response, so preferably someone or place different. [Missing finial](//muut.com/u/brownstoner/s3/:brownstoner:tvNy:missingfinial.jpg.jpg)
Guest User | 4 years ago
8
andriywww1990 | 4 years ago
object(WP_User)#4989 (8) {
  object(stdClass)#5001 (12) {
i just went on Heights woodworking website to contact Vaughan about an unrelated matter. one of the first pictures that popped up was someone turning something on a lathe. it looks like they have one. give them a call.
stevecym | 4 years ago
object(WP_User)#4991 (8) {
  object(stdClass)#4988 (12) {
Its a finial on a newell. Most finials are round and turned on lathes. Most shops that i know of in nyc do not have lathes. I have a lathe but it would be much easier for a stair builder to turn it to exacting specifications as they recreate balusturs and those can be detailed.
Stevecym and doors by are the same. I can possibly turn a finial if it is simple. I often make round astragals for doors by turning them and cutting them in half. If ops finial is simple and not a round ball, i might be able to do it. I also make bowls as a hobby.
By the way, many of the big finials are removeable. They lift off. I am not sure if they were designed that way so they can be lifted off to pass furniture over and up the stairs but people often ask me to glue their finials down and i tell them that is a bad idea. I suspect these were made loose so they can be removed and hence get lost.
cate | 4 years ago
object(WP_User)#4990 (8) {
Lots of woodworking shops in Brooklyn that can do exterior doors to Landmarks specifications can also make a newel post. It is wise to research the age and style of your house so you commission something you will not regret. If you are in a row, your neighbors will likely have the originals.
object(WP_User)#4980 (8) {
  object(stdClass)#4986 (12) {
i took a look a aaron’s website. he list his shop equipment and does not seem to have a lathe needed to turn wood. i bet JMP, the stair builder does.
string(6) "203483"
Thank you- those are both great recs
nvdeowqycge | 4 years ago
object(WP_User)#5025 (8) {
  object(stdClass)#5023 (12) {
    string(6) "209566"
    string(11) "nvdeowqycge"
    string(34) "$P$BhH3umgEOTep78eG6t05737Qyg5Lrp/"
    string(29) "lorrainegeoffroy1@hotmail.com"
    string(19) "2024-07-03 15:02:48"
  int(209566)
Aaron Lenza at Rooted Construction does amazing work!
true | 4 years ago
object(WP_User)#4993 (8) {
  object(stdClass)#4994 (12) {
    string(6) "201026"
    string(4) "true"
    string(34) "$P$BEUJpFfrB4EOKjujGRA.dR9IbqBgrV1"
    string(15) "truetrueart-biz"
    string(16) "true@trueart.biz"
    string(19) "2017-08-10 14:11:38"
    string(9) "True True"
  int(201026)
I had great luck with JMP Wood in East Brooklyn.
object(WP_User)#5022 (8) {
  object(stdClass)#4977 (12) {
Adriatic or dykes cant turn one for you? Can you make or do you have a drawing?
