Maintaining exposed exterior brick wall on end of brownstones.
I live in a brick/brownstone building that is last in a row of buildings, with no adjoining building on one side. We’ve noticed quite a bit of efflorescence (salt forming on the inside of the brick wall, due to water seeping through the cracks) in our basement. I was wondering if anyone else was in the same position of having an entire side of building exposed to the elements, and what experience you’ve had with maintenance/repairs/etc.
squeakycleaningca
alex | 6 years and 8 months ago
object(WP_User)#5086 (8) {
object(stdClass)#5083 (12) {
string(4) "1928"
string(4) "alex"
string(4) "alex"
string(20) "arichman33@gmail.com"
string(19) "2007-08-15 17:26:38"
string(4) "alex"
int(1928)
Efflorescence as you are aware is due to water intrusion and the salt contained within it. A lot of time brick buildings on older buildings are not maintained which can lead to conditions such as this. Intermittent brick re-pointing is important to help mitigate water intrusion in older buildings. Additionally, you should look at the coping or lack thereof at the top of the brick wall. If this is not performing correctly, water will seep into the wall instead of draining away.
Best of Luck,
Alex Furini, RA
Furini Architects, PLLC
object(WP_User)#5089 (8) {
object(stdClass)#5090 (12) {
string(4) "1928"
string(4) "alex"
string(4) "alex"
string(4) "alex"
int(1928)
Best of Luck,
Alex Furini, RA
