Leaking steam radiator in Victorian home
What is the best way to resolve a leaking Victorian steam radiator? Is it adament to replace it or are there trusted ways to repair (without worry of breakage)?
Also- how do you FIND someone who works on these radiators with experience and real knowhow? I can find contractors in the NYC area, but they do not serve upstate NY.
4thstreet
mholesh | 9 years and 3 months ago
object(WP_User)#5025 (8) {
object(stdClass)#4972 (12) {
string(6) "191845"
string(7) "mholesh"
string(34) "$P$BJbS0svK/..0WD9MU0hsSbSA9d4AGQ/"
string(7) "mholesh"
string(17) "mholesh@gmail.com"
string(19) "2017-08-10 13:31:55"
string(25) "Martin Olesh Martin Olesh"
int(191845)
I agree with the plumber
Master Plvmber | 9 years and 3 months ago
object(WP_User)#5024 (8) {
object(stdClass)#5023 (12) {
I’m a steam heating expert and professional consultant. Most often, a steam radiator leaks because of a systemic problem. Rarely do I encounter cracked cast iron sections, but I do come across leaking shut off valves which are best to replace, though some people do prefer to “repack” their leaking stems. A qualified contractor/technician/plumber would make that call for you.
Most often, however, radiators leak water from their air vents and this is constantly misdiagnosed as a problem with the vent itself. If water is getting to that portion of a radiator, then the system has a problem that needs to be corrected.
– John Cataneo
shahnandersen
object(WP_User)#141227 (8) {
object(stdClass)#5035 (12) {
string(1) "6"
string(13) "shahnandersen"
int(6)
Is the leak from the control (on/off) valve, the pressure valve (at the other end of the radiator) or from a rust spot on the radiator itself?
ellenlourie | 9 years and 3 months ago
object(WP_User)#141229 (8) {
object(stdClass)#141230 (12) {
open radiator valve fully.
