I need advice for the new stairway
Attached here is a photo of the existing short stairway that leads from my house side entrance into the kitchen (which is behind the closed door). This will all be replaced with a completely new stairs that is going to be custom made for me. The new landing, right side wing-shelf and the actual stairs frame will be built out of plywood, on top of which all will have ceramic (non-slippery type) tiles glued-on. My question is about the two side areas that I circled in the photo. My contractor is proposing that I leave out the wooden sides in the new build, and make the new stairway go directly into the wall sheet-rock. Otherwise he says, it will look ugly if I have to put a little trim made out of wood on the left side on top (you can see a small molding) and then insert wooden riser side holders. Are there any other solutions you can suggest? I don’t think I can make a tiny ceramic molding on the left side of the stairs, and it seems like having wood on the sides in combination with ceramic steps + sheetrock might indeed look ugly. Your input is much appreciated for comments or further ideas. P.S. The new design will make the step size & slanting more correct than on the existing stairs as shown in the photo and in addition, there is no way to make the steps wider, as there is a double-beam just under the right-side wing shelf area.
mystiky
in General Discussion 12 years and 8 months ago
kani1987 | 11 years and 6 months ago
object(WP_User)#5045 (8) {
string(6) "183086"
string(8) "kani1987"
string(34) "$P$Bhdndupd/2VE0ysGXv7VjUvQiMj62k."
string(23) "xinxinan.join@gmail.com"
string(19) "2017-08-10 13:54:24"
int(183086)
You can take a look at this house, and I bought this house.[akley outlet store](http://www.oakleysunshine.com/ “oakley outlet store”)
object(WP_User)#5044 (8) {
object(stdClass)#5043 (12) {
string(6) "183086"
int(183086)
You can take a look at this house, and I bought this house.[](http://www.oakleysunshine.com/ “oakley outlet store”)
no-permits | 12 years and 8 months ago
object(WP_User)#5040 (8) {
object(stdClass)#5046 (12) {
string(6) "176811"
string(10) "no-permits"
string(16) "c90027@gmail.com"
int(176811)
what?
mystiky | 12 years and 8 months ago
object(WP_User)#5043 (8) {
object(stdClass)#5045 (12) {
string(5) "86928"
string(7) "mystiky"
string(34) "$P$BY2fDbcypC3b6SAQyHI.0EpF.7Bost."
string(7) "mystiky"
string(19) "mystiky@hotmail.com"
string(22) "/forums/users/mystiky/"
string(7) "mystiky"
int(86928)
I am now thinking about just using sheetrock on the sides, with ceramic tile glued directly on it (in triangles with the steps). This way, there is no skirt, no trim/molding to worry about and it will be easu to clean the stairs, not worrying about hitting the sides. Opinions..???
