How to ventilate an interior, ground floor bathroom?
Can anyone recommend an air filter and dehumidifying unit that I can install in the basement directly below the problematic bathroom? I have no plausible way to duct the damp exhausted air to the exterior.
centerslope
in General Discussion 2 years and 2 months ago
centerslope | 2 years and 2 months ago
object(WP_User)#5185 (8) {
object(stdClass)#5173 (12) {
string(5) "46653"
string(11) "centerslope"
string(21) "centerslope@ymail.com"
string(26) "/forums/users/centerslope/"
string(19) "2010-04-05 02:22:42"
int(46653)
Thank you for your suggestions!
cate | 2 years and 2 months ago
object(WP_User)#5184 (8) {
object(stdClass)#5183 (12) {
It’s not ideal but a window that opens into a hall plus opening the door might be better than nothing. We have original 1895 internal windows to admit light and air to pantries and bathrooms. The pantry window opens to the hall. (The bathroom windows open to an air shaft that vents into the house’s cock loft, which in turn has vents in the roof. This setup is surprisingly effective.)
Guest User | 2 years and 2 months ago
Maybe you could incorporate low profile ducting like this? Designed for laundry but recently I adapted it for a bathroom exhaust that had very limited pathway. Volume of airflow is severely limited but better than what you have now
https://www.amazon.com/gp/aw/d/B0049IBM7Y/ref=yo_ii_img?ie=UTF8&psc=1
object(WP_User)#5187 (8) {
object(stdClass)#5188 (12) {
string(5) "46653"
int(46653)
ceiling height is already low for going below the beams.
object(WP_User)#5189 (8) {
object(stdClass)#5190 (12) {
string(5) "46653"
int(46653)
Not close enough, and it would require crossing support beams, and then lining the unused flue through 3 floors with intact surfaces.
object(WP_User)#5188 (8) {
Is the bathroom anywhere near your main stack and an air shaft, or a chimney with a secondary vent line?
Unfortunately a common “solution” is to vent to the space behind the ceiling/walls. Bad idea. Find a way to vent outside via duct. Maybe you could try an awkward in wall filter and dehumidifier system that continuously drains to waste pipe? I find it hard to believe designing and installing that would be easier than exhausting outside
object(WP_User)#5216 (8) {
object(stdClass)#5146 (12) {
string(5) "46653"
int(46653)
This must be a fairly common problem in 1 to 2-family Brooklyn rowhouses.
justinromeu26 | 2 years and 2 months ago
object(WP_User)#5186 (8) {
object(stdClass)#5180 (12) {
Cate, there is. But plenty of older bathrooms do not have these fans and op says they have no way to do it. They might have a way and it might be cost prohibitive.
object(WP_User)#5146 (8) {
object(stdClass)#5147 (12) {
Kicking this up. Isn’t there a rule that if you don’t have a window in a bathroom, you have to have a fan with a duct venting to the exterior and replacing a certain amount of parts of air per minute or something?
