Hole to basement between garden and back of brownstone
What is the purpose of the hole between garden and basement window that looks into hole. that goes into basement… To give a window for servants forced to live in basement? to hide slaves? to flood the basement during hurricanes? to help burglars enter basement from garden?
In other words, if we seal up the hole or insert a closed window, will oil boiler blow up without an outlet to fresh air??
anntares
cate | 3 years and 9 months ago
object(WP_User)#4993 (8) {
object(stdClass)#4981 (12) {
The openings and window wells are useful to get equipment in and out both via the front and rear. Contractors have used both for scaffolding, ladders, and other equipment and materials, as well as debris. The front one is essential in the event the boiler needs replacement. As well, at least one if not two windows are needed for fresh air intake for running the boiler. We’d like add another air vent to improve the ventilation in general.
object(WP_User)#4991 (8) {
object(stdClass)#4994 (12) {
Because my shop is in my basement where my boiler is ….
object(WP_User)#4992 (8) {
object(stdClass)#4995 (12) {
Catboot: for combustion equipment to work properly, it must have air for the intake in addition to an air outlet. If one were to perfectly seal a cellar, the heating device would be starved for air. I suppose enough air could be an inch gap under a 32″ inch wide door to the basement.
Because my shop is in my basement where my shop is, i was going to build a pretty air tight room around my boiler and in the wall of that room i was going make a say 12×16″ hole and cover it with an a/c filter so the boiler could breath clean air.
catboot | 3 years and 9 months ago
object(stdClass)#4996 (12) {
string(5) "56593"
string(7) "catboot"
string(7) "catboot"
string(7) "catboot"
int(56593)
Most brownstones have an opening into the cellar in the front and in the rear. We find it handy to have it so that we can get items out of storage and into the back yard (for example, any backyard items we put away for the winter). No, your home will not blow up if you close off that opening. Your oil boiler is vented via the chimney.
object(stdClass)#5005 (12) {
FWIW I too have a hatch and a “hole” (as termed by the OP) in the rear of my house that is similar to the front coal chute. I’ve often wondered about it’s original purpose.
object(WP_User)#5023 (8) {
object(stdClass)#5050 (12) {
Asaph: in the back of the house?
jdever755 | 3 years and 9 months ago
object(WP_User)#5022 (8) {
object(stdClass)#5024 (12) {
string(6) "189792"
string(9) "jdever755"
string(34) "$P$BLXcoJ9i6nkDICgp42lez7aDulxqov1"
string(19) "jdever755@gmail.com"
string(19) "2022-05-26 18:24:44"
string(25) "Julian Drury Julian Drury"
int(189792)
It is a coal chute!
object(stdClass)#5007 (12) {
Many people don’t know the difference and I don’t know if the distinction is made that often outside of NYC.
(Yes—I know the difference. My ground floor, with the entrance under the stoop, is a basement. The window-less floor under it is a cellar).
object(WP_User)#5002 (8) {
object(stdClass)#5003 (12) {
Is it into the cellar or basement?
