Heating Mystery
Something weird is happening with our heat. The wood floor and staircase on our garden level is warm, giving off heat, as though we have radiant heat, which we do not. Normally the staircase area is a bit chilly since we have a skylight on the top floor. The front room on the garden level, where the thermostat is located, is unusually warm. The thermostat says it’s 72 degrees, when normally it’s usually about 65-68 (or, if the heat is off in the winter, even colder). The heat won’t come on unless I turn the thermostat to 76 or so, and it won’t stay on unless I open a window.
Our tenants say they’re cold on the top floor. This has been going for maybe a few weeks now, I think.
I checked out the cellar today around 5 pm when the heat was off and no one was running hot water. Nothing seemed unusual. One of the heating pipes and one of the hot water pipes were warm to the touch. A cold water pipe was sweating.
We had boiler service pretty recently. Speculating they might have turned up the temperature of the water, and perhaps it’s enough to heat the floor, though it seems strange. (It had been set slightly lower than normal originally to prevent scalding. I have not noticed the water is any hotter when taking showers.) We have a hot water cast iron radiator system fueled by oil. Anyone have any insight?
cate
object(WP_User)#4993 (8) {
object(stdClass)#4979 (12) {
Wow—inadvertent radiant heat.
cate | 3 years ago
object(WP_User)#5018 (8) {
object(stdClass)#5021 (12) {
So the great heating mystery has been solved. When a boiler repairman visited a few weeks ago, he accidentally toggled a high/low switch, reversing the temperatures of the radiator hot water and the domestic hot water. As a result, the domestic hot water pipes snaking around our cellar hanging from the ceiling were almost burning hot to the touch, and radiating enough heat up through the wood floor, incredibly, to heat the entire house except when outside temps dropped to 25 degrees or below. Unfortunately, the situation also caused our 130-year-old wood floors in the hall just above one of the hot water pipes to cup. How peculiar!
justinromeu26 | 3 years ago
object(WP_User)#5017 (8) {
object(stdClass)#5019 (12) {
Sorry. You have hot water radiators, not steam. Ignore what i said about pressure.
cate | 3 years ago
object(WP_User)#5021 (8) {
Thanks, Homeinspector. When the heat is actually running (such as when I open a window), the pressure seems to be fine, and everything is running as normal.
object(stdClass)#5000 (12) {
Read what the heating guys said a few weeks back about pressure being a top floor issue. Did they tamper with the pressure switch?
Really, these are questions for a heating specialist. Even on my own boiler or when i took care of boilers in a building, we never touched the pressure. That was done by a licensed person.
cate | 3 years ago
object(stdClass)#5017 (12) {
We could go the whole winter like this, never using the heat. A miracle. The planet will be saved. But the top floor is cold, and both for reasons of humanity and law it cannot drop below 68 degrees or so.
kdub3131 | 3 years ago
object(WP_User)#5000 (8) {
string(6) "190570"
string(8) "kdub3131"
string(63) "$wp$2y$10$0bCbn/RFgr8GqVTF3iQh2eOQOzjSbM7WDr2Q7rTPzNP7VFYkC47kO"
string(17) "kelechi@gmail.com"
string(19) "2024-02-22 16:51:15"
string(25) "kelechi wami kelechi wami"
int(190570)
Nice!
