Heating in Garden-Level Brownstone Extension
My tenant’s bathroom is located in an extension. The existing in-wall heater (which wasn’t really sufficient) died. Recommendations on the best way to heat the space? Recommendations on a contractor to do the work?
rene.soloserrato
fiordiligi | 6 years and 7 months ago
object(WP_User)#5094 (8) {
  object(stdClass)#5038 (12) {
    string(5) "48967"
    string(10) "fiordiligi"
    string(63) "$wp$2y$10$k4TBzCyFz.aqO2sL4OgmcOD5g2CB1NbyN9/jtLbA2A941.RwOS5lq"
    string(31) "customerservice@broadwayart.com"
    string(19) "2010-04-22 21:02:29"
  int(48967)
Don’t know about the legality in NYC, but upstate I use an envi wall-mounted space heater. They’re inexpensive, occupy very little space, and plug into a regular outlet.
Master Plvmber | 6 years and 7 months ago
object(WP_User)#5093 (8) {
  object(stdClass)#5092 (12) {
“Small direct vent gas heater is the way to go.”
Not in NYC. Just try to vent one of those things legally. I dare ya.
hmcghee | 6 years and 7 months ago
object(WP_User)#5089 (8) {
  object(stdClass)#5095 (12) {
    string(6) "192147"
    string(7) "hmcghee"
    string(34) "$P$BGJL53b8vI2KpJzBGI8oibVoipmIUz/"
    string(7) "hmcghee"
    string(17) "hmcghee@gmail.com"
    string(19) "2017-08-10 13:39:07"
    string(29) "Heather McGhee Heather McGhee"
  int(192147)
these type of electric radiant heater can be installed in the wall. https://www.radiantsystemsinc.com/heater-features/pricing
2345bcde | 6 years and 7 months ago
  object(stdClass)#5096 (12) {
    string(6) "182176"
    string(8) "2345bcde"
  int(182176)
  object(stdClass)#5097 (12) {
Installing a loop of hot water baseboard heater using the boiler water is usually a pretty simple process, especially if it’s on the same floor as the boiler or even one floor above. After that it gets trickier, but still very doable.
www.72Fmechanical.com
slopefarm | 6 years and 8 months ago
  object(stdClass)#5098 (12) {
    string(3) "655"
    string(9) "slopefarm"
  int(655)
Just thinking out loud. If you were renovating, I would say electric radiant heat under the tiles. But I don’t think that is what you are looking for. One story extensions are hard because they coo faster than the rest of the house. We had some luck in an extension with ceramic electric baseboards. The ceramic heats more slowly and cools off more slowly than regular metal element baseboards, so it mimics an old fashioned steam radiator a little more. But that may be a tricky solution in a wet space.
