Gutter overflows on heavy rain
My gutter is clean, but every time it rains very hard it overflows. I suspect that the downspout needs to be snaked. Has anyone else dealt with a similar issue?
Any recommendation for a gutter cleaning/maintenance company?
ellenbkeane
in General Discussion 4 years and 5 months ago
namahs | 4 years and 5 months ago
object(WP_User)#5010 (8) {
object(stdClass)#4989 (12) {
string(5) "26703"
string(6) "namahs"
string(6) "namahs"
string(16) "eychan@gmail.com"
string(6) "namahs"
int(26703)
Look for any roofing company to clear the downspout/gutter. The leaves/debris from the fall season would usually cause blockage over time. Do you have gutter guard that prevents large debris from going inside? Normally the block would be on the angle downspout and they would just take that piece off to clear it. good luck
andriywww1990 | 4 years and 5 months ago
object(WP_User)#5009 (8) {
object(stdClass)#5008 (12) {
can you take it a part at the base? ours here are not tied to the sewer but they still clog from time to time and we take it apart and i put a stick up there and all sorts of stufff will come out. the clog is often down low.
even though our gutter might look clear and it might now, i have finally realized that no matter what, i have to go up there in the fall and every spring and check it.
