Electrician rec to install ceiling fan with plaster medallion
Hi all,
Thanks in advance to the Brownstoners who provide excellect advice for preserving our historical homes in BK! I have a home I have been working on over the years and have found this site invaluable.
I have a room with a plaster medallion and original light fixture. I would like to swap out the current fixture for a ceiling fan (we don’t have AC). I have seen on the forum that fans can use the old gas line for support to preserve the medallion and avoid breaking it. An electrician usually recommended by this site came out it to look at it and they say they need to break the medallion even though the gas line is there. Can anyone recommend electricians who have done this type of work?
Thanks much in advance!
eamonnsbest
object(WP_User)#4975 (8) {
  object(stdClass)#4988 (12) {
Cate,
FWIW we have fans hung from Fr as pipes in a two rooms. There is BX wiring and metal boxes that go around the gas pipes, which are cut off—no gas. The fans hang from the threaded ends of the gas pipe—an arrangement that seems very secure.
cate | 4 years and 10 months ago
object(WP_User)#5020 (8) {
  object(stdClass)#5023 (12) {
The issue might be that the wiring in the ceiling is old and does not contain the metal box required by code for safety. The electricians may be unable to get the new box in there without breaking the medallion and/or cutting the gas pipe. (Beware, your gas could still be active AND cutting the pipe can destroy the stove lines — they are typically not separate, especially in the upper stories.) As well, you may have a medallion with a tiny opening through which no box will fit. And, finally, if you do manage to get a box up there, it will need to be heavy duty enough for a fan to hang from. For all these reasons, we decided not to install fans. We use window and floor fans instead.
eamonnsbest | 4 years and 10 months ago
object(WP_User)#5021 (8) {
  object(stdClass)#5041 (12) {
    string(6) "203573"
    string(11) "eamonnsbest"
    string(34) "$P$B8uf2lMypTljpNipDdBOiVBQ9MidjI1"
    string(22) "eamonnsbesthotmail-com"
    string(23) "eamonnsbest@hotmail.com"
    string(19) "2018-02-27 05:39:34"
    string(11) "Eamonn Best"
  int(203573)
Thank you, Bob! I know Lamp Warehouse—I’’ll pay them a visit.
  object(stdClass)#4991 (12) {
My previous answer assumes that the gas line in question is cut off.
It CAN be done, but the installer will have to put together a fitting that will thread onto the gas pipe. When I bought my first fan, years ago, Lamp Warehouse, on Ft. Hamilton Parkway provides a “ gas hicky “ but they didn’t have those when I bought another fan more recently. Maybe they can recommend someone to install your fan.
