Current window installation cost (Marvin, landmarked)
I know this is a common topic – just wanted to confirm if $2k per window is the going rate these days for installation of Marvin wood windows in a landmarked district?
xuytbjicwnofjdde
12
hasibur.rahman07 | 2 years and 5 months ago
object(WP_User)#5237 (8) {
    string(6) "193777"
    string(16) "hasibur.rahman07"
    string(16) "hasibur-rahman07"
  int(193777)
You only need to remove it if the window is thicker. Otherwise you can airseal just fine with it in place.
stoopsitter | 2 years and 6 months ago
object(WP_User)#4965 (8) {
  object(stdClass)#5021 (12) {
    string(3) "899"
    string(11) "stoopsitter"
    string(2) "JB"
  int(899)
Vard01 mentions that the possibility of a brick mold installation. This should be emphasized. If you’re looking for maximum energy efficiency, this is what you’ll want. It means that all the old wood or aluminum framing elements are removed and new material is used from one masonry edge (brick mold) to the other. It’s the best way to do the job but significantly more expensive than sash-only window replacements, which in my opinion are a waste of money. I haven’t priced this in years so can’t comment on current costs.
hasibur.rahman07 | 2 years and 6 months ago
object(WP_User)#4983 (8) {
  object(stdClass)#5238 (12) {
    string(6) "193777"
  int(193777)
One window is one double hung that has an upper and a lower sash. Price varies depending on the installer. 15 windows at 2k is 30k. Some prices may not include framing, insulation or brick mold replacement.
ysabil | 2 years and 6 months ago
  object(stdClass)#5240 (12) {
    string(6) "190637"
    string(6) "ysabil"
    string(34) "$P$BUmROxa2mcZr4ZU/0gxeOQZow9gyjM0"
    string(6) "ysabil"
    string(17) "ysabil@icloud.com"
    string(19) "2023-03-26 00:14:37"
    string(7) "I B I B"
  int(190637)
Related question: I have heard the ~$2k per window install cost number previously. For double hung Brownstone windows, does a window mean one double hung unit, or does each window in the double hung unit count as “a window” (i.e. is it roughly $4k to install one double hung)? Asking because I need to replace 15 double hung windows in my brownstone (not Landmarked) and am curious if I am looking at ~$30k install costs, or ~$60k!
mzaman718 | 2 years and 6 months ago
object(WP_User)#5238 (8) {
  object(stdClass)#4965 (12) {
    string(6) "190831"
    string(9) "mzaman718"
    string(34) "$P$BxFKMNtlEsRf8Y0h1KdHcIcuyjVGGl/"
    string(17) "mzaman718@aol.com"
    string(19) "2023-06-08 15:51:54"
    string(27) "Mohamad zaman Mohamad zaman"
  int(190831)
Hello @umanish; we have this company called Norwood, we always use them for Landmark projects like yours, because they offer a 15-year warranty on the paint from the manufacturer. Nobody in the industry offers that, and for the $500 paint job you will get, most likely the warranty will be only for one year; plus you have to make sure they follow Marvin’s stipulations so is also covered by the warranty. We have a showroom in Manhattan if you would be interested in taking a look at the Norwood and Marvin windows.
  object(stdClass)#5239 (12) {
    string(6) "193777"
  int(193777)
Excellent. Fiberglass is more insulating than wood. Marvin windows have improved but European-manufactured windows are the gold standard.
xuytbjicwnofjdde | 2 years and 6 months ago
  object(stdClass)#5241 (12) {
    string(6) "209569"
    string(16) "xuytbjicwnofjdde"
  int(209569)
Yes, install would be from the same place that I would get the windows from. I am still waiting on others to get more quotes / explore the other options. Based on all the posts here and just other research, it does seem like Marvin is a safe bet, though certainly not the only good option out there.
object(WP_User)#5239 (8) {
    string(6) "193777"
  int(193777)
Is the place you are buying the windows from installing them? If so 20k is not bad. Why Marvin? There are a range of acceptable Landmark Windows and some materials are more energy efficient and may be cheaper than Marvin.
object(WP_User)#5241 (8) {
  object(stdClass)#4983 (12) {
    string(6) "193777"
  int(193777)
I am sorry I was not clear. The proper install has nothing to do with the price or someone who calls themselves an expert. It is having a proper understanding of how air seal and insulate around the window to minimize energy loss. You should be paying for the quality of the install which may or may not correspond to the price. Just to be clear I am not opining on anyone’s price or quality of work. I am only stressing that you need to look out for yourself as leaky windows will create a very uncomfortable living situation.
I would recommend you get 5 quotes and ask them to walk you through the install and the materials they are using.
  object(stdClass)#5237 (12) {
    string(6) "209569"
  int(209569)
Thanks – definitely, I’m happy to pay up for expert installation. Just to clarify (maybe it was obvious), this is just the installation cost. The actual windows are separate ($2k +/- each for “regular” sized, around $4k each for large parlor windows – wood in & out double-hung ). I also learned that these come unpainted outside, so that is being quoted at around $500 additional for each window. So a regular sized window is landing at around $4.5k before tax
    string(6) "193777"
  int(193777)
That’s a good price. There will be people who charge more or less. What’s really important is the installation. A poor installation will make a good window inefficient. Make sure they know how to install to minimize issues that can happen with a poor install.
cate | 2 years and 6 months ago
That sounds roughly in the ballpark to me. However, a giant parlor floor to ceiling window will surely be much more.
