Contractor recommendations for finishing cellar
We have a 19’x45′ rowhouse in PS close to 5th Avenue. The cellar floods occasionally, especially with the bigger named storms. There seems to be some seepage from the stone wall facing the backyard. We have a humidifier connected to a sump, which helps.
The other issue is that the old tin ceiling is falling down exposing the beams. This causes a constant rain of plaster/brick dust that covers everything.
So we’d like to seal the foundation, put down some concrete/tile floor, and replace the ceiling. We just want a clean dry space to store things.
Anyone have any contractors they could recommend?
Thank you!
ixmfrteyhywobz
in General Discussion 3 years and 2 months ago
markwalker | 3 years and 1 month ago
object(WP_User)#4993 (8) {
  object(stdClass)#5038 (12) {
    string(6) "202629"
    string(10) "markwalker"
    string(11) "mark Walker"
  int(202629)
It is expensive. because you are talking major work. Be prepared, It is awful, messy, dusty, dirty work. Involving wheelbarrows full of mud, cement mixers churning outside your house pumping concrete into the basement, possibly replacing pipes that run under the floor, replacing old wiring and panels, etc. The men who do this work are heroes, in my book. But if you can afford it it is sooo nice to step into a bright clean and useful space.
About $40 grand I would say at minimum because you will need an electrician and plumber. Not counting the water bill.
object(WP_User)#4994 (8) {
  object(stdClass)#4995 (12) {
there was a person who wrote on here a few weeks back talking about the floor and drainage enhancements and i believe they had said 40k. just two weeks ago, if that.
stoopsitter | 3 years and 1 month ago
object(WP_User)#4998 (8) {
    string(3) "899"
    string(11) "stoopsitter"
    string(2) "JB"
  int(899)
I’d assume more than $20k for a new cellar floor. You’ll want the contractor to excavate down far enough to lay several inches of sand and gravel BEFORE the vapor barrier is laid. And while the floor is dug up, you’ll also be well advised to add some French drains and a couple of strategically located new sump pumps.
cate | 3 years and 2 months ago
  object(stdClass)#4991 (12) {
Putting in a thick concrete floor with a vapor barrier can run $20K or so. The only proper way to seal a foundation wall that I know of is to dig down from outside and repoint from outside, then fill in again.
ceci | 3 years and 2 months ago
object(WP_User)#4990 (8) {
  object(stdClass)#4989 (12) {
    string(6) "177206"
    string(4) "ceci"
    string(4) "ceci"
    string(4) "ceci"
  int(177206)
I recommend Tommy Construction Specialist, tel:# 718-968-9207 of Bergen Beach. Has completed masonry jobs for me and very happy with his work. In the business along time.
