Changing configuration
Hello Brownstoners,
Its been a while. I am interested in purchasing a property that is currently set up as a double duplex that I would like to turn into a triplex over garden rental. To do this, the kitchen that is located on the top floor would need to be moved to the parlor and if I file it, I would need a new CO. Since it is already a 2 unit, and would stay a 2 unit, would this trigger any need for sprinklers and what would happen to my property taxes? Any feedback from anyone who has actually done something similar would be greatly appreciated. Thank you in advance.
stuyheights
in General Discussion 6 years and 10 months ago
12
randolph | 6 years and 10 months ago
object(WP_User)#5046 (8) {
object(stdClass)#5058 (12) {
string(5) "26171"
string(8) "randolph"
int(26171)
> @Ed_Kopel_Arch
can you explain what “the building does not front on a substandard road.” means? what is the “existing 2nd means of egress” – a fire escape? and what does “the value of the alterations to this ‘prior code’ building do not exceed 60% of the value of the existing building” mean? how do they arrive at 60%? did you need to fit all 3 of those requirements or just one of 3? it all seems very arbitrary.
agdipierro
object(WP_User)#5039 (8) {
object(stdClass)#5036 (12) {
string(6) "193981"
string(10) "agdipierro"
int(193981)
The sprinkler exemption was granted for the following code citations:
Per FC 501.4.3.1 sprinklers protection is not required because the building does not front on a substandard road.
Per MDL 194 (1) sprinkler heads in rooms is not required because this building has an existing 2nd means of egress
Per BC 901.9.4 the value of the alterations to this ‘prior code’ building do not exceed 60% of the value of the existing building. Therefore, the provisions of 903.2.8 do not apply and a sprinkler system is not required
stuyheights | 6 years and 10 months ago
object(stdClass)#5090 (12) {
string(5) "17815"
string(11) "stuyheights"
int(17815)
@GreenThinker- This isnt a gut rehab. The house is 100% in tact and all original. All I wanted to do was change it from a double duplex to a triplex over a garden rental but based on the feedback im getting here, I dont think its worth the risk. Ill leave it as a double duplex.
GreenThinker | 6 years and 10 months ago
object(WP_User)#5089 (8) {
object(stdClass)#5115 (12) {
string(5) "98498"
string(12) "GreenThinker"
string(12) "greenthinker"
int(98498)
@Stuyheights- regardless on the configuration, if you’re going to be doing a Gut Rehab and plan on filling everything 100% kosher, department of finance see’s that you’ve done major work to the building and reassess the property value and/or is allowed to increase taxes in excess of the 6% per year, 20% over 5 years limit.
object(WP_User)#5090 (8) {
object(stdClass)#5039 (12) {
string(5) "17815"
int(17815)
@Randolph- Im sorry to hear this. You have convinced me to keep the double duplexes and to figure out how to make that configuration work.
object(stdClass)#5070 (12) {
string(5) "26171"
int(26171)
> @StuyHeights
> being a 2 and keeping it a 2
i did that, taxes more than doubled a year later. they somehow use that dollar amount on your DOB filings to reassess the property value and there is pretty much nothing you can do about it as far as i know.
object(stdClass)#5089 (12) {
string(5) "17815"
int(17815)
@Randolph- I heard from a few people I would not need sprinklers but taxes I am very unsure about. I heard if you change the usage they increase substantially but not sure about it being a 2 and keeping it a 2, just changing the configuration but I’m certain we would need a new CO if I went that route.
object(WP_User)#5070 (8) {
string(5) "26171"
int(26171)
> @Ed_Kopel_Arch
> Sprinklers were not required.
explain…
object(stdClass)#5046 (12) {
string(5) "26171"
int(26171)
> @StuyHeights
yes sprinklers, your taxes will at least double.
string(5) "17815"
int(17815)
@No-Permitz- I plan to rent out both units but the building is 100% original and the layout really doesnt work that way. One kitchen is on the garden floor and the other is on the top right rear.
yudashasom | 6 years and 10 months ago
It’s unclear if you want to use the building as a rental, or rent the garden and live above. If it’s a rental building, a double duplex would perform better.
agdipierro
object(WP_User)#5035 (8) {
object(stdClass)#5033 (12) {
string(6) "193981"
int(193981)
I am completing a similar conversion (duplex/duplex to simplex/triplex) in Park Slope. Sprinklers were not required. Contact me offline at ek@edkopel.com.
