Carpenter or Contractor to build Exterior Bike Shed
Looking for a carpenter or contractor to build an exterior bike shed for 4-5 bikes. I want someone local who can customize to the exact space I have and install (do not want to order a pre-fab online). Location is secure so not overly concerned with security mechanism, but the space requirements are unique. Thanks.
JeremyL
in General Discussion 5 years and 6 months ago
Guest User | 5 years and 6 months ago
string(6) "201901"
I have done two different minimal space things that might work for your needs.
1) buy this plus an add on piece for a fifth bike, and hire for an aluminum awning to be built over top: https://www.amazon.com/gp/aw/d/B01B2OAJ6C/ref=yo_ii_img?ie=UTF8&psc=1
2) buy two of the less wide three-bikes version of the above item, bolt them back to back, and hire for an aluminum awning installed above
A little pricey. Very professional and sturdy finish. No complaints from our tenants
greenworks | 5 years and 6 months ago
object(WP_User)#5054 (8) {
  object(stdClass)#5057 (12) {
    string(6) "193898"
    string(10) "greenworks"
  int(193898)
Op is the most local person available.. DIY. It is not a tough project.
resident2 | 5 years and 6 months ago
object(WP_User)#5058 (8) {
  object(stdClass)#5059 (12) {
You say you would like someone local; where is local for you?
helen40
object(WP_User)#5063 (8) {
  object(stdClass)#5066 (12) {
    string(6) "189636"
    string(7) "helen40"
    string(7) "helen40"
    string(13) "hkcln@aol.com"
  int(189636)
Most competent carpenters should be able to handle this unless you are planning on adding water and electricity, and even then some would take on the job. I would think you would be hard-pressed to find a GC to take on a job this small.
