California Stucco repair recommendation (Exterior)
Hi! I had a roofing leak that is in the process of getting fixed, but the roofer told me that while they do stucco work, they don’t deal with the stucco type on my back wall. They mentioned it was California stucco and required someone skilled in that type of work to repair. I’ve attached a pic for reference. Once the roof issue is resolved, I’m looking for someone to fix the stucco. Any thoughts, comments, and recommendations would help. Thx! [IMG_1054 copy](//muut.com/u/brownstoner/s3/:brownstoner:F3tV:img_1054copy.jpg.jpg)
shaterras01
8
shaterras01 | 4 years and 7 months ago
object(WP_User)#4989 (8) {
object(stdClass)#5001 (12) {
string(6) "205044"
string(11) "shaterras01"
string(34) "$P$BxiF9MgKLqCHvOmGJJo6Hf2on91cdY."
string(20) "shaterras01gmail-com"
string(21) "shaterras01@gmail.com"
string(19) "2018-03-21 20:00:17"
string(17) "Shaterra Severino"
int(205044)
Thank you, @Eman137 and @jandrew. I can see a netting behind the damaged parts so what you are explaining about the hallow and net setup falls in line. I will search out EIFS contractors and also check out the link @jandrew
After looking at the picture a bit more, I’m leaning towards Eman’s assessment.
cate | 4 years and 7 months ago
object(WP_User)#4988 (8) {
Great, thank you so much for clarifying, janedrew.
Hi Cate, I did not use them and I don’t think you should use them for masonry. I posted that link specifically for EIFS as it’s very hard to find EIFS people and they have good reviews compared to some of the other EIFS companies.
As you know cellar issues require more than masonry skills, they need to have a good understanding of air and water infiltration and how to deal with that effectively.
@eybrokemyeye California stuff is the stucco you see in Cali. It’s not necessarily EIFS so make sure. I can’t tell from your photos .
object(WP_User)#5025 (8) {
object(stdClass)#5023 (12) {
Janedrew, please excuse me if I missed this part: Have you worked with the mason/construction company whose website you posted and would you recommend them? (We are looking for a construction outfit that builds structures and works in townhouses to do a variety of cellar repairs, including some structural stucco). Thank you.
EIFS can be very problematic if not done correctly. It is usually XPS/EPS followed by mesh then stucco. Just search for EIFS contractor. I pasted a link to a mason on this forum that also does EIFS. Let me see if I can dig that up.
I think that he meant that it is EIFS, a synthetic stucco laid over a foamboard base with a synthetic netting ….tap on the wall …if it has a hollow sound, it is EIFS. It is basically cheap crap if not done right. Look up contractors who deal with this stuff. Put up a close up of the damaged area, since it looks like there is no netting layer
