Boiler check before using for first time of season
Is it necessary to check the boiler / radiators annually, before using for the first time each season? Or is it just good precautionary thing to do? We haven’t used the heat since it was cold last season (I guess March), but have been tempted to put it on recently. This is our first time in the house going from summer season into fall…
xuytbjicwnofjdde
13
debbernst | 2 years and 5 months ago
object(WP_User)#4976 (8) {
object(stdClass)#4988 (12) {
string(6) "203428"
string(9) "debbernst"
string(34) "$P$BySXxnzbqumJAVUDFQZcvAUOmLAZ8d0"
string(18) "debbernstgmail-com"
string(19) "debbernst@gmail.com"
string(19) "2019-07-12 22:15:44"
string(3) "D B"
int(203428)
thank you! any recommendations for companies to come out rather than working with the different vendors associated with each boiler and a/c system in brooklyn?
object(WP_User)#4977 (8) {
object(stdClass)#4978 (12) {
In addition to yearly service on the heating equipment, you should also get the chimney cleaned regularly. Once a year for a chimney with a wood burning fireplace, once every two years for an oil-burning boiler, and possibly every three years (I’m not sure) for a gas-fired system. We have our oil boiler checked every year around June or July, when the technicians are less busy. In addition to heating radiators in cold season, our boiler makes hot water all year round.
ellenlourie | 2 years and 5 months ago
object(WP_User)#4975 (8) {
object(stdClass)#4955 (12) {
Todays photos [IMG_9827](//muut.com/u/brownstoner/s3/:brownstoner:BqGI:img_9827.jpeg.jpg) [IMG_9820](//muut.com/u/brownstoner/s3/:brownstoner:XZyg:img_9820.jpeg.jpg) [IMG_9828](//muut.com/u/brownstoner/s3/:brownstoner:6Bde:img_9828.jpeg.jpg) [IMG_9826](//muut.com/u/brownstoner/s3/:brownstoner:Q7c8:img_9826.jpeg.jpg) [IMG_9822](//muut.com/u/brownstoner/s3/:brownstoner:eCwj:img_9822.jpeg.jpg)
object(WP_User)#4981 (8) {
object(stdClass)#4960 (12) {
Proper yearly maintenance saves on emergency calls during the season. Prevents parts failure. Boiler /burner devices and parts must be disassembled, cleaned checked. As a sample, small gas fired steam boiler incomplete list of items:
Check the base of the chimney
Check chimney termination on the roof
Check the condition of the vent connector.
Flush boiler water.
Skim boiler
Add water conditioner
Disassemble and clean control trim piping
Disassemble and clean boiler feeder
Disassemble and clean boiler low water cutoff
Inspect, clean burners
Inspect master vents
Disassemble and clean boiler manual reset low water cut off
Disassemble and clean boiler water level sight glass
Test boiler spill switch
Check boiler outdoor control operation and settings
Clean/replace ignition electrodes
Clean/replace ignition cables
Perform combustion analysis, set boiler for optimum combustion.
Prepare list of deficiencies if found.
object(stdClass)#4969 (12) {
“who is Bob Marvin?” Just a frequent commenter since this website and brownstone owner for nearly a half century. I happen to have forced hot air heat, which is slightly uncommon in NYC.
lkrshacmzcy | 2 years and 5 months ago
object(WP_User)#5036 (8) {
object(stdClass)#5046 (12) {
string(6) "209518"
string(11) "lkrshacmzcy"
int(209518)
Technically: you should 100% have any Heating Equipment Maintained/Serviced/Tuned Up every year; every company has their own and process so just make sure they actually submit to you what they did.
The truth though is no does this and then waits until the first cold night, realizes they have a problem and call a Heating Company negging for services in the middle of the night.
object(WP_User)#5047 (8) {
object(stdClass)#5037 (12) {
string(6) "203428"
string(3) "D B"
int(203428)
thank you – who is Bob Marvin?
object(stdClass)#4971 (12) {
BTW I’m not an expert on furnaces, but I HAVE lived with one for nearly a half century. The things are far simpler than steam or hot water heat.
object(stdClass)#4972 (12) {
Right Steve. Change the filter or, if you have a reusable one, like on mine, hose it down. My HomeServe plan includes annual service, so I usually have them visit around the start of the heating season. There isn’t usually much fii in e HomeServe to do, although last year they replaced some parts. Also, with furnaces or boilers, don’t forget to change the batteries in your thermostat.
object(WP_User)#4968 (8) {
object(stdClass)#4970 (12) {
You have to replace the filters on a furnace regularly, right? Bob Marvin has more info.
object(WP_User)#4972 (8) {
string(6) "203428"
string(3) "D B"
int(203428)
what about furnaces – do these need to be looked at regularly? or inspected ?
object(WP_User)#4970 (8) {
object(stdClass)#5047 (12) {
Oil-burning heating systems must be serviced annually or you can have horrible problems such as fires!
Master Plvmber | 2 years and 5 months ago
object(WP_User)#5037 (8) {
object(stdClass)#4968 (12) {
Steam heating boilers need a little maintenance once a year. That doesn’t mean you can’t turn it on before that service is performed but you should get it done at some point. The radiators are typically fine but any boiler room should have a look by a pair of experienced eyes occasionally.
