Bilco roof hatch
I plan to install a bilco type s aluminum roof hatch and I’d like opinions about whether the thermal barrier option is worth the extra money. It’s a few hundred dollars more.
slimc
dorkofwindsor | 5 years and 2 months ago
object(WP_User)#4998 (8) {
object(stdClass)#5051 (12) {
personally I would absolutely do it. my Bilco is rather cold in the winter and my stairwell quite cold as a result. I understand urbandad’s rationale with cost to area ratio, but if you think of it in the extreme it is certainly not. If you had a 36×36 hole in your roof that would certainly be a big deal after thousands in insulation you are doing. Its more of a weakest link exercise like acoustics rather than an isolated cost/benefit analysis.
make sure your curb is insulated… I get interior condensation as well so I might recommend xps on the curb. just make sure they don’t leave the curb walls empty.
object(WP_User)#4999 (8) {
object(stdClass)#5000 (12) {
I think the standard bilco hatches are insulated, and that shouldn’t cost several hundred bucks, so what I’m guessing is that this feature refers to a thermal break, or a barrier to thermal bridging. Now unless you’re home is very well insulated, I doubt you’ll notice much difference from this.
slimc | 5 years and 2 months ago
object(WP_User)#5003 (8) {
object(stdClass)#4997 (12) {
string(6) "177080"
string(5) "slimc"
string(5) "slimc"
string(5) "slimc"
int(177080)
Urbandad – this roof hatch has morphed into a larger project which includes a new roof and blown-in insulation. So I’m thinking it might be worth considering.. But yes, normally it wouldn’t make sense to just do that small area.
object(stdClass)#4996 (12) {
Well you’d be paying several hundred dollars to insulate 3 square feet, so most likely your money would be better spent on other insulation projects unless that area is particularly important for some reason.
