Basement Waterproofing
Any recommendations for masons/water-proofing contractors that repoint basement stone walls where mortar has failed?
owest
in General Discussion 7 months ago
daveb | 6 months ago
object(WP_User)#5053 (8) {
  object(stdClass)#5039 (12) {
    string(6) "219526"
    string(5) "daveb"
    string(63) "$wp$2y$10$bxhTbp/rxz.H6Tc.kiqH5OBml3cUpctU5cyZwaHPANBEcEkutaA82"
    string(5) "daveb"
    string(23) "david.brioso@hearst.com"
    string(19) "2024-10-04 13:26:42"
    string(5) "daveb"
  int(219526)
dudeonocean: Sorry for the late reply, I used:
The foundation waterproofing company I used is called City Suburb Inc. The contact is Ravinder Singh: citysuburb07@gmail.com. I thought they were very good. Fast, clean, efficient. https://citysuburbinc.com/
dudeonocean | 6 months ago
object(WP_User)#5051 (8) {
  object(stdClass)#5050 (12) {
    string(6) "180974"
    string(11) "dudeonocean"
    string(63) "$wp$2y$10$FhIdm5l/djUdO2d/1HCjlO1xhwvxNU3bubpZO2pxg8.c1MN.UsBlG"
    string(20) "jborrero23@gmail.com"
  int(180974)
daveb can you share the name of the contractor that your used?
bklynteacher | 7 months ago
object(WP_User)#5052 (8) {
  object(stdClass)#5054 (12) {
    string(6) "185457"
    string(12) "bklynteacher"
    string(63) "$wp$2y$10$QnSOcxLebWxOE.8QSqmSoOiwxs6WO8siZQTdybdW9R1BYSUFoOB0e"
    string(15) "dedalus@usa.com"
    string(19) "2017-08-10 13:57:32"
  int(185457)
I’ll highly recommend Mohammed Kabir at 917-407-9058. He paved our patio, repointed brick, restored brownstone, and painted. He gave me his advice and an estimate to improve the condition of the brick and stone in our cellar; but I haven’t pulled the trigger on that job. He has done similarly good work for two of my neighbors. Though he’s rather difficult to understand, we’re all happy customers, and all rather amazed by his low prices! You can tell him that Stephen on South Oxford Street recommended him.
daveb | 7 months ago
object(WP_User)#5046 (8) {
  object(stdClass)#5055 (12) {
    string(6) "219526"
    string(5) "daveb"
    string(5) "daveb"
    string(5) "daveb"
  int(219526)
I had the back of the house waterproofed in 2021 after Hurricane Ida after seeing water literally pour through the foundation. These men had to crawl under my steel frame deck (about 3 feet of clearance), excavate 6 feet down, repair the mortar, apply a waterproof membrane, back fill, and repave the area under the deck. Took them three days, highly recommended. On top of that, I run two dehumidifiers in the basement year round, and run a window ac unit in the summer – all of which helps. I’m still susceptible to heavy storms which overwhelm the sewers, but when that’s an issue the water doesn’t enter through the foundation, it comes up my shower drain and traps, not as easy to address compared to the foundation.
workisfun | 7 months ago
  object(stdClass)#5056 (12) {
    string(6) "184143"
    string(9) "workisfun"
  int(184143)
We have two dehumidifiers running at around 35% – 40%. Also installed vertical vapor barriers along rhe rubble walls and a water barrier beneath the slab. The barriers are tucked into a perimeter drain, which leads to the sump pump. Couldn’t do external because of accessibility and cost. We’re happy with our interventions, though. Will always be fighting the moisture levels in the air.
Brownstone Home Inspection | 7 months ago
object(WP_User)#5055 (8) {
  object(stdClass)#5052 (12) {
    string(6) "191038"
  int(191038)
keep in mind, mortar itself is not impervious to moisture. there are additives that can be added to mortar and 4000 psi concrete, say on a floor, comes close. these wall will never be ideal. even if you get it good, it will need maintenance every few years.
  object(stdClass)#5057 (12) {
    string(6) "191038"
  int(191038)
robert:
i tell people that more often than not, there will be moisture (water) coming in through the mortar or high humidity in general. i am using a hygrometer and see readings of 50% – 72% and these are too high. readings of 60% in the air can push the moisture content of wood above 25% and we can see termites thrive. readings over 50% can support mold in dark places. that is what i see in MOST places in the city but sometimes we get an area that has historically remained dry (as evident by no inactive termite damage; most brownstones have some termite damage. if someone asks, i will elaborate on why and what this means for this type of construction).
some of the high humidity is brought on by seasonal wet periods and some are ever present conditions (a lot of water in the ground).
instead of spending money on a loosing battle for nothing, i say run two small humidifiers in these basements. if there is water pouring in through the mortar joints, go ahead and seal but that might not be perfect because if can come in through the floor.
I did have someone write me today about these drains installed around the perimeter that catch the water and direct them to a sump pump. if things are that bad, i can say that they do work because my aunt had one installed and it worked and i speak to customers who have them. i see them all the time. but water has to be directed to the drains and that can be problematic.
BobMarvin | 7 months ago
  object(stdClass)#5058 (12) {
So Steve, are you saying that cellars like mine, with rubble foundations, will always be somewhat damp?
  object(stdClass)#5059 (12) {
    string(6) "191038"
  int(191038)
simple repointing and parging will not hold water back. The best way to do this is by “positive side” water proofing (on the outside). because this is an expensive undertaking, people often do “negative side” water proofing (on the inside using liquid applied products). know that negative side water proofing fails because the weight of the water pressing on it will cause the liquid product to decouple with the wall.
Before calling a contractor, read about negative side water proofing so you have an understanding of some of the products and challenges. when the contractor is on site, talk about some of the products. if he has not heard of some of them or cannot talk to them or offer up similar products that do what you are talking about, he is not who he says he is (as a professional, we get through these questions on the initial phone call so we do not waste time).
i do water leak investigations on the upper portions of buildings. i do not usually come out for basements because water is often everywhere outside these houses. even if you pour a pad with high psi concrete to help move water away, it will go in the ground and move laterally to your wall.
steve
