Asbestos in flooring & ceiling?
Hi All,
When faced with 1970s vinyl sheet flooring in a brooklyn townhouse, does one assume asbestos?
If so, has anyone had experience either removing this, or laying a floor on top of it if the floor is stable and even?
Also, has anyone had a patterned ceiling removed as part of asbestos removal, and what was the cost?
Thanks!
jimyjames.robert96
8
object(WP_User)#5031 (8) {
  object(stdClass)#5019 (12) {
Sqibsie, you mean the ceiling tiles? Hopefully they are non friable?
The flooring by nature of what it is will be nonfriable.
string(6) "200737"
FYI there is a big difference between friable and non friable, so you are lucky that you probably have the non friable kind, which is much cheaper to remove. You can get a sample tested at labs in Manhattan, it costs about $30 a sample. Make sure to test the adhesive and the flooring. It’s cheapest for you to bring them in yourself rather than hiring a dude to do it for you.
cate | 3 years and 3 months ago
object(WP_User)#5032 (8) {
  object(stdClass)#5033 (12) {
1970s sheet vinyl is unlikely to contain asbestos. However, it doesn’t matter, you should get everything tested, which is very easy and affordable. As well, the under layers and the glue can contain asbestos. If you want to leave it there and cover it with something, this is certainly an option, although details will vary depending on your particular conditions. Discuss details with your architect and contractor long in advance.
object(WP_User)#5035 (8) {
  object(stdClass)#5041 (12) {
When i said “not tiles” above, i should have said “as well as tiles” or not just tiles.
object(WP_User)#5034 (8) {
  object(stdClass)#5036 (12) {
So i just found an article on line that said that vinyl sheet flooring, not tiles, also contained asbestos.
Also, in this house i am in, circa 1928, they must have had 4 layers of flooring over the original rubberized whatever floor that i could not get up. I ripped most up and assumed it contained something and ended up leaving the first layer and going over it with wood. Be careful if you begin lifting stable flooring. You might open a can of worms.
jimyjames.robert96 | 3 years and 3 months ago
object(WP_User)#5041 (8) {
  object(stdClass)#5032 (12) {
    string(6) "190005"
    string(18) "jimyjames.robert96"
    string(34) "$P$B0JohxzsMmWluFNH3NFp6AUlR2U68X."
    string(18) "jimyjames-robert96"
    string(28) "jimyjames.robert96@gmail.com"
    string(19) "2022-08-25 09:48:53"
    string(21) "jimy james jimy james"
  int(190005)
Thanks! This is much appreciated.
As far as I can tell, it is not tiles it is in sheets that were rolled out. I’m unsure what is underneath though it is glued down in some way….
object(WP_User)#5036 (8) {
  object(stdClass)#5035 (12) {
Ok, unless we have something tested, we ALWAYS assume worst case. This goes for anything dangerous or health hazard or that which can bring the authorities down on you (if you ripped that out and put it in the waste stream and got caught, the fines will be a lot).
The 9×9 tiles were the almost guaranteed to be acm (asbestos containing material).
We ripped out a floor with 12×12 tiles and i suspect it had acm in it. This was decades ago, Before the city said we could not rip out non friable acm. Now i would have it tested.
I am not sure about sheet flooring.
In so far as leaving it or covering it. The consensus seems to be that it acm is stable, it is ok to cover. Or leave.
I am not a licensed asbestos person. I have had to have it removed by licensed people and pulled pieces for sampling and anything i said above could be wrong.
Steve
Brownstonehomeinspection.com
  object(stdClass)#5042 (12) {
AFAIK vinyl/asbestos flooring came as rigid tiles.
