Adding an Extension
Can anyone help me estimate the cost to add a two-story extension to a brick townhouse? We’re talking 20 feet wide, 13 feet deep. (We have checked the FAR and there is no legal issue with doing this.)
rana-foroohar
in General Discussion 9 years and 11 months ago
29
rana-foroohar | 9 years and 11 months ago
object(WP_User)#5245 (8) {
    string(6) "192795"
    string(13) "rana-foroohar"
    string(34) "$P$Be..zpYSvEZIzQvnpPgpLLqDntPfFI0"
    string(17) "rana@foroohar.com"
    string(19) "2024-02-23 10:20:21"
    string(27) "Rana Foroohar Rana Foroohar"
  int(192795)
> @resident2
> Plus the forever much higher Real Estate Tax reassessment on your Real Estate Taxes.
If there a way to find out in advance how much an improvement like an extension or changing a C of O would alter the tax bill?
object(WP_User)#5243 (8) {
  object(stdClass)#5244 (12) {
    string(6) "192795"
  int(192795)
> @resident2
SimpleTwig | 9 years and 11 months ago
object(WP_User)#4990 (8) {
  object(stdClass)#4997 (12) {
    string(6) "161782"
    string(10) "SimpleTwig"
    string(10) "simpletwig"
    string(51) "http://www.brownstoner.com/forums/users/simpletwig/"
  int(161782)
If the existing extension is legal then you can replace the entire structure with the same square footage, assuming the FAR allows for it (which you said it does). The cost is higher than just typical floor area in a home because you have to dig down and build footings/foundation walls, roof/drainage, and build 3 exterior walls, plus hauling material by hand. This exterior and structure work raises the cost per SF substantially. For 2 floors you should plan on at least $150k to $200k as a minimum to get it done right, another $50k to $75k for nice interior finishes and windows. Because an addition like this is exposed to the elements on multiple sides, I highly recommend very good R value insulation.
If you’re in a historic district adding two floors to the rear usually isn’t a problem as long as it is not visible from the street… (same for roof additions) but then again if you are replacing an existing structure with a new one this shouldn’t be too much of an issue with landmarks anyway.
randolph | 9 years and 11 months ago
object(WP_User)#5244 (8) {
  object(stdClass)#5245 (12) {
    string(5) "26171"
    string(8) "randolph"
  int(26171)
> @resident2
how much will an extension add to your tax bill? is it the additional square footage or the value of the house post renovation that causes the increase? is there a formula to how this is calculated?
resident2 | 9 years and 11 months ago
object(WP_User)#5246 (8) {
  object(stdClass)#5247 (12) {
Plus the forever much higher Real Estate Tax reassessment on your Real Estate Taxes. This is a cost that stays with you forever and your architect & contractors never tell you to expect.
  object(stdClass)#5248 (12) {
    string(5) "26171"
  int(26171)
> @thenext
> My FAR will permit me to do 10′ x 15′ extension on up to 3 levels. I’m guessing $200 sq. Ft So roughly $450K
I am far from a mathematical genius, but what is with everyone’s math?!
(10′ x 15′) x 3 floors = 450 sqft
450sqft x $200/sqft = $90,000
so how are you arriving at $450,000 ?
thenext | 9 years and 11 months ago
  object(stdClass)#5249 (12) {
    string(6) "181340"
    string(7) "thenext"
    string(34) "$P$B6CGcXSjhWcypVeWejxBzGwrYrvPcA0"
    string(7) "thenext"
    string(23) "metabolic@optonline.net"
    string(19) "2014-01-31 14:48:07"
    string(7) "thenext"
  int(181340)
I agree. I think most of the money will go toward Glass. depending on your Window plan. Ideally I would Glass out the back wall. Already received a quote from NANA Wall for about 45K
object(WP_User)#5248 (8) {
  object(stdClass)#4965 (12) {
    string(6) "181340"
    string(7) "thenext"
    string(7) "thenext"
    string(7) "thenext"
  int(181340)
I’m looking to do the same type of extension on my brownstone. I’m not sure of cost yet. I’m just in the planning stage myself. My house already has a sprinkler system. My FAR will permit me to do 10′ x 15′ extension on up to 3 levels. I’m guessing $200 sq. Ft So roughly $450K
  object(stdClass)#5264 (12) {
    string(5) "26171"
  int(26171)
> @lsp2
> at least $500K.
(20 x 13) x 2 = 520 sqft
for this to cost 500k that means spending 960/sqft ?! unless the finishes are insanely high end, i see no reason why it would cost so much.
kximbnfgxgjwe | 9 years and 11 months ago
object(WP_User)#4965 (8) {
    string(6) "209660"
    string(13) "kximbnfgxgjwe"
    string(34) "$P$BnfxmyKi.6tv1d0ubnQEvQGnu6aqtU1"
    string(23) "vinceandvinny@gmail.com"
    string(19) "2024-07-05 06:34:51"
  int(209660)
Our house already had a 20 x 15 extension at the garden level, and we are adding a same-sized extension at the parlor level (so, no new foundation work needed – just building up one level). This is part of a very large 7 figure gut renovation of the whole house, but I asked the contractor how much we would have saved if we hadn’t done the extension, and he said about $250K. I’m not sure if we would have needed sprinklers if we hadn’t done the extension, but the sprinklers are about $50K. I would be surprised if your proposed extension wasn’t therefore at least $500K.
nsloper | 9 years and 11 months ago
object(WP_User)#5264 (8) {
  object(stdClass)#4970 (12) {
    string(6) "179532"
    string(7) "nsloper"
    string(34) "$P$BMPNmN/DQl0nH1nY8Yu0F8SL2UDPah/"
    string(7) "nsloper"
    string(20) "jen@pinnacleprep.com"
    string(48) "http://www.brownstoner.com/forums/users/nsloper/"
    string(19) "2017-08-10 14:03:36"
    string(7) "nsloper"
  int(179532)
It will cost in the hundreds of thousands, but could end up being quite nice. One big challenge is digging the foundation, which will have to be done by hand since you can’t get a backhoe behind a row of houses. It doesn’t necessarily have to be an Alt1 change; that is a question for your expediter. If the use of the house stays the same, it may be able to be an Alt2. I did a 20×20 two story expansion and it took 2 years and was a tremendous amount of trouble. But it was worth it because buying a bigger building would have been a greater cost than enlarging the one I already owned. It was a major undertaking, but we love our house now and are set to be here for the next 30 years.
Good luck with your project!
  object(stdClass)#5270 (12) {
    string(5) "26171"
  int(26171)
> @MC NYC
> there is an existing extension that has to be demolished and rebuilt (because of extensive damage)
i doubt the extension is legal, so i am going to guess no. but as obama says, no one here can tell you, and you most likely cannot sort it out yourself. you have to pay an expeditor a crapload of money to figure it out for you! welcome to the joys of owning a home in NYC.
obama | 9 years and 11 months ago
  object(stdClass)#5271 (12) {
    string(6) "179993"
    string(5) "obama"
    string(34) "$P$Bacwrg7Vw7kroTxESMj0Um0BSejveQ1"
    string(5) "obama"
    string(18) "jgoldgar@gmail.com"
    string(32) "http:///forums/users/anonlurker/"
    string(19) "2017-08-10 14:04:39"
    string(5) "obama"
  int(179993)
you need to consult them. no one on this site is going to be able to answer all your questions around this since every property/job is unique.
object(WP_User)#5270 (8) {
    string(6) "179993"
    string(5) "obama"
    string(5) "obama"
    string(5) "obama"
  int(179993)
that’s where an architect and expeditor come into play.
  object(stdClass)#5272 (12) {
    string(6) "192795"
  int(192795)
> @obama
> this will definitely require an ALT 1 because you’re altering the square footage!
Does this also apply if there is an existing extension that has to be demolished and rebuilt (because of extensive damage), but the new extension is the same square footage as the old?
    string(6) "192795"
  int(192795)
> @obama
object(WP_User)#5272 (8) {
    string(5) "26171"
  int(26171)
> @obama
THANKS OBAMA!
  object(stdClass)#5243 (12) {
    string(6) "179993"
    string(5) "obama"
    string(5) "obama"
    string(5) "obama"
  int(179993)
Arkady | 9 years and 11 months ago
If you’re in a landmark area, FAR may not matter.
