Bathtub removal
I’m currently living in staten island,I was wondering how much would average cost to remove & install a new tub. standered size tub.Any recommendations? Greatly appreciated.
joey3125
in General Contractors 11 years ago
brownstone1171 | 10 years and 9 months ago
object(WP_User)#5096 (8) {
object(stdClass)#5108 (12) {
string(6) "206184"
string(14) "brownstone1171"
string(34) "$P$BieKLObOhY0JNOgx1SsG/IauzJf1Rp1"
string(23) "brownstone1171gmail-com"
string(24) "brownstone1171@gmail.com"
string(19) "2020-05-19 15:17:02"
int(206184)
Hi Joey, Total cost for removing the old tub and installing a new one can run $1,500-$3,500 or more, but averages $2,500-$3,000 depending on the ease of access, local rates, the quality of the new fixtures, and the extent of the repairs/replacements for the walls, plumbing and flooring. If the replacement tub is larger and heavier than the old bathtub, you might also need to install larger copper water pipes and a bigger-capacity hot water heater.Make sure work is done by a professional. You can get help from [online directories](https://porch.com/new-york-ny/remodeling-contractors/cp) like Porch, Red Beacon and many more to find the right one. Good Luck …!!!
object(WP_User)#5097 (8) {
object(stdClass)#5098 (12) {
string(6) "206184"
int(206184)
