Basement mold removal
http://cdn.brownstoner.com/4e020f1749a76-
A bit of background. The molded area is a small closed partition space at the back of the house. The area is about 10×10 in size and to the right of it is the boiler room, directly to the left of the infected wall is a half bathroom. Above the infected area is our kitchen and bathroom. I noticed a couple of black patches a couple of months ago but it seem to grow exponentially the past couple of weeks.
Has anyone dealt with mold removal? I am thinking about cutting open the sheetrock to see if I can find the source of the mold, if there isn’t. I plan to install a dehumidifier around the area to keep the humidity under 60%. Do I need to hire a mold inspector? How common is this?
Thanks in advance.
namahs
in General Contractors 14 years and 10 months ago
aboveb | 14 years and 7 months ago
object(WP_User)#5094 (8) {
  object(stdClass)#5119 (12) {
    string(6) "179704"
    string(6) "aboveb"
    string(34) "$P$B1YkjPTnzeqJuNQUjhtE6UUQl3Qa380"
    string(6) "aboveb"
    string(35) "directories@abmoldremediationnj.com"
    string(47) "http://www.brownstoner.com/forums/users/aboveb/"
    string(19) "2017-08-10 13:41:11"
    string(6) "aboveb"
  int(179704)
According to EPA, if an area contaminated with mold is greater then 30 square feet, you MUST reach out for specialist to perform a mold removal for you. The thing is, sometimes mold is hidden behind the walls, under the carpet, etc. Its always a good idea to have a mold inspection in case you suspect large mold contamination.
You can do it yourself, take walls apart, etc, but if you get the inspection, they would use a special mini cameras to check your wall space without taking it apart!
If you in New Jersey, here is a great company – http://www.abmoldremediationnj.com . Good Luck!
BHS | 14 years and 10 months ago
object(WP_User)#5095 (8) {
  object(stdClass)#5096 (12) {
    string(5) "11181"
    string(3) "BHS"
    string(3) "bhs"
    string(3) "BHS"
  int(11181)
I strongly agree with the previous commenter: it’s a leak, not general humidity, and you need to fix the source of the water before fixing the cosmetic issues. Don’t bother with a mold inspector. It may be a simple plumbing fix. You’re right to be opening the wall to see what’s going on.
bowl-of-dicks | 14 years and 10 months ago
object(WP_User)#5099 (8) {
  object(stdClass)#5093 (12) {
    string(5) "12647"
    string(13) "bowl-of-dicks"
    string(15) "cf80q@yahoo.com"
    string(13) "bowl of dicks"
  int(12647)
If you do not remedy the source of the mold, it will just come back. And it sounds like it could be a number of culprits, given the proximity to kitchen/bathrooms. If the mold is isolated to just this one area, it reinforces that you do not have a general humidity problem like in a basement (no need for long term dehumidifer use). As for clean up, start with bleach and a scrub brush.
