Is a deck subject to 30 ft. rear setback rules?
I am thinking about adding a deck off my parlor floor. The existing extension is 30 ft off the rear property line, in line with the applicable zoning. Would a deck also be subject to the 30 ft set back rules? Thanks as always…..
housepoor
in Decks and Porches 14 years and 3 months ago
housepoor | 14 years and 3 months ago
object(WP_User)#5060 (8) {
object(stdClass)#5004 (12) {
string(5) "71781"
string(9) "housepoor"
int(71781)
Thanks everyone….
dazednconfused2 | 14 years and 3 months ago
object(WP_User)#5059 (8) {
object(stdClass)#5058 (12) {
string(6) "209624"
string(15) "dazednconfused2"
int(209624)
Look at this: http://bit.ly/v6t8PN
urbanexteriors | 14 years and 3 months ago
object(WP_User)#5004 (8) {
object(stdClass)#5055 (12) {
string(5) "21301"
string(14) "urbanexteriors"
string(34) "$P$BynvYd0n5TimUJCs201Gk..GHJFJO7."
string(19) "urban-exteriors-2-2"
string(24) "steve@urbanexteriors.biz"
string(55) "http://www.brownstoner.com/forums/users/urbanexteriors/"
string(19) "2017-08-17 21:36:28"
string(15) "urban exteriors"
int(21301)
It’s my understanding that you can build an 8′ deep parlor floor deck in a 30′ yard. You can build beyond that in a deeper yard. You can have steps down to the back yard. As to combustibility, you are required to use non-combustible material within 3′ of your property lines. If you stay 3′ away, you can use wood. Steve
object(stdClass)#5061 (12) {
string(5) "71781"
int(71781)
OP here. Jock — did you mean **non-**combustible _or_ are there different rules if it is wood vs iron? What determines how deep the deck can extend into the 30′ rear yard? I am thinking about 8′ ~ 10′. Is a stair allowable down to the backyard? Thanks.
pigthree | 14 years and 3 months ago
object(stdClass)#5062 (12) {
string(5) "14451"
string(8) "pigthree"
string(13) "pig-three-2-2"
string(9) "pig three"
int(14451)
Not a 100% on this, but think its 8ft if off the ground and non combustable. if on the ground, can be wood and be larger.
jockdeboeraia | 14 years and 3 months ago
object(WP_User)#5061 (8) {
string(5) "40876"
string(13) "jockdeboeraia"
int(40876)
It can extend a certain amount into the rear setback if to be of combustible construction.
