Water Dripping Through Skylights
Water Dripping Through Your Skylight?
A public service message from an old-time “brownstoner”
Don’t worry–it happens whenever their’s a real blizzard–heavy snow combined with strong wind. Snow blows through the skylight housing vents, melts on the leaded glass beneath, and drips down. It’s a rare occurrence in Brooklyn. I’ve owned my house since 1974. The first time I noticed this happen was in the two blizzards of late January and early February 1978. Since then snow has blown into our skylight vents perhaps a half dozen times. Interestingly this did not happen during the [so far] record snowfall of February 2006, when there wasn’t much wind.
Don’t worry–just put down towels to catch the water. It doesn’t mean that there’s anything wrong with your skylight housing–it’s just another charming feature of old house living.
BobMarvin
in Chimney and Fireplace 3 months ago
BobMarvin | 2 months ago
object(WP_User)#5005 (8) {
object(stdClass)#5062 (12) {
I should have waited until today to post this. There wasn’t much wind a few weeks ago, but tomorrow may be different. High wind means snow blowing through the skylight vents. I’m planning on having old towels resdy to catch the drops.
cate | 2 months ago
object(WP_User)#5006 (8) {
object(stdClass)#5007 (12) {
As a roofer explained it to me, the skylights have openings at their corners (where the topmost seams end at the corners) purposefully to allow moisture to escape so condensation does not build up inside and drip into the house. But supposedly if any water did work its way inside from such an opening it would be only a tiny drip or two. We had a newly replaced skylight that just would not stop leaking. It leaked for years as we tried to figure out where the leak was coming from via trial and error. Turned out there were some spots (near a chimney and the party wall) where in heavy rain there was enough water that it would rise up and above the base of the skylight and flow into hidden openings inside the skylight base. Tarring over and inside the base of the skylight on one half of the skylight worked and stopped the leak.
object(WP_User)#5011 (8) {
object(stdClass)#5004 (12) {
We had two such vents installed years aho when we had insulation blown into the cockloft, so I guess the skylight vents aren’t needed. Since they only leak during extreme blizzard conditions I haven’t seen a need to change them. They did not leak during the recent snow storm.
cate | 2 months ago
object(WP_User)#5062 (8) {
object(stdClass)#5003 (12) {
A roofer can add vents (that do not leak) to a flat roof. They are small, round things. We put in three a while ago, have never had any problem with them. In addition, we also have three skylights, all of which have airshafts or another opening to the house below. (Two can be opened and closed via a window; the one over the stair is fixed.) Air goes up into the cockloft through those openings under the skylights and the air in the cockloft escapes outside via the three new vents.
BobMarvin | 3 months ago
object(WP_User)#5004 (8) {
object(stdClass)#5006 (12) {
True, but I think the vents in the skylights were intended to vent the cockloft. This should be done in some way.
Putnamdenizen | 3 months ago
object(WP_User)#5003 (8) {
object(stdClass)#5011 (12) {
string(4) "1667"
string(13) "Putnamdenizen"
string(13) "putnamdenizen"
int(1667)
Yeah, but I think it also shows that the traditional skylights leak air and heat. I think sum of them – in one family structures – were meant to have a decorative flat panel below, while those in multi-family hallways were meant to leak? Maybe for ventilation or in case of fire reasons? I am much happier having replaced mine with a openable modern skylight – velux. Remote control and powered by a solar photovoltaic strip.
