Pre existing Floor drain basement
If we have a pre existing drain in basement floor next to new hot water heaters but drain leads into floor and not into outside will that pass plumbing inspection? Once we pass is it sufficient to have a pan under the heaters with over flow alarm?
firsthouse
in Building Code 10 years and 3 months ago
firsthouse | 10 years and 3 months ago
object(WP_User)#5007 (8) {
  object(stdClass)#5052 (12) {
    string(6) "185478"
    string(10) "firsthouse"
    string(34) "$P$BoecUtPViwz6d5I28L1J2k1/4D9w5C."
    string(18) "sbhaskel@gmail.com"
    string(19) "2017-08-10 13:56:22"
  int(185478)
Thank you!!!!
eileengray | 10 years and 3 months ago
object(WP_User)#5008 (8) {
  object(stdClass)#5009 (12) {
    string(6) "185785"
    string(10) "eileengray"
  int(185785)
It’s what is called a dry drain – intended to catch water when the boiler ‘thermos’ breaks. As long as it is not connected to a sanitary waste, it is ok.
GreenThinker | 10 years and 3 months ago
object(WP_User)#5052 (8) {
  object(stdClass)#5012 (12) {
    string(5) "98498"
    string(12) "GreenThinker"
    string(12) "greenthinker"
  int(98498)
The inspector will just see that there is a drain, he’s not going to question where it goes.
  object(stdClass)#5006 (12) {
    string(6) "185478"
  int(185478)
Will a drain that solely leads into the ground pass inspection or does it need to be attached to a pump and drainage outside into a drainage pipe?
mozeeatupu | 10 years and 3 months ago
  object(stdClass)#5005 (12) {
    string(6) "176749"
    string(10) "mozeeatupu"
  int(176749)
Why would you not use the drain?
