2 kitchens, 1 family home, icard shows both kitchens existing in 1965
I own a one family brownstone that was built 120 years ago. There is no C of O. The building has always been a designated one family. I was told it is typical of one family victorian buildings in my neighborhood ( Harlem ) to have been built with 2 kitchens. One on the basement level ( one flight above the cellar ) and another on the top flight. The i-card shows both kitchens noted in same place as now, in 1965. The d.o.B may be coming in to inspect, because of a complaint. Question: Will the second kitchen be considered illegal for a one family home, even though the D.O.B. noted its existence on the icard in 1964, and there is no violation.
mrsbrownstoneowner
in Building Code 12 years and 5 months ago
mrsbrownstoneowner | 12 years and 5 months ago
object(WP_User)#5060 (8) {
  object(stdClass)#5004 (12) {
    string(6) "180696"
    string(18) "mrsbrownstoneowner"
    string(63) "$wp$2y$10$3XCiAJbXzbryzhqNMvNAS.X4AXB7kxoauaX8RiWbVqz7b5VeLazbi"
    string(17) "JLevey321@aol.com"
    string(19) "2017-08-10 14:06:36"
  int(180696)
thank you for all your help! to be clear: I understand the DOB complaint/inspection process. The issue is: THE ICARD ENTRY IS FROM 1965 Does anyone know , if there is a SPECIFIC DATE making existing “legal”.
daveinbedstuy | 12 years and 5 months ago
object(WP_User)#5059 (8) {
  object(stdClass)#5058 (12) {
On a complaint, they will make three attempts to investigate and then close it out. Unresolved complaints have no ramification to a later sale, only unresolved VIOLATIONS which they can only issue when the actually encounter and see one.
object(WP_User)#5004 (8) {
  object(stdClass)#5055 (12) {
Either you don’t answer the door or you tell them that you are not the homeowner and that he isn’t here at the moment.
dnk | 12 years and 5 months ago
  object(stdClass)#5061 (12) {
    string(5) "46107"
    string(3) "dnk"
    string(34) "$P$Bc/fuQ6M6AurKgSr2TPjNRasEkYaWi1"
    string(3) "dnk"
    string(28) "dkeegan@laskerfoundation.org"
    string(18) "/forums/users/dnk/"
    string(19) "2017-08-10 13:36:02"
    string(3) "dnk"
  int(46107)
dave, Can you do that? Answer the door and tell DOB that they cannot come in?
object(WP_User)#5055 (8) {
  object(stdClass)#5059 (12) {
“The d.o.B may be coming in to inspect, because of a complaint.” Under no circumstances should you let the DOB in to inspect unless you have pulled permits for some work where it will be a requirement.
arch007 | 12 years and 5 months ago
  object(stdClass)#5062 (12) {
    string(5) "29788"
    string(7) "arch007"
    string(7) "arch007"
    string(16) "master@gmail.com"
    string(7) "arch007"
  int(29788)
If it’s on the I-card you are golden! HPD was the building dept long ago. I don’t know when the split to DOB happened but I am surprised I-cards were still in use in 1965\. one time at DOB I showed a 1940 I-card to a plan examiner when we were renovating a store in an area that was not zoned for retail. He depressingly mumbles “your lucky” http://nyc-dob.com
