repair of ceiling medallion?
When the contractor updated the ancient wiring in our 1910 building in Ridgewood, Queens, he damaged a ceiling medallion, which I’m pretty sure is original to the house. I want to save it! Can anyone recommend a master plasterer who could repair it/would be willing to take this project on? Any idea how much something like this would cost? Photo attached. Thanks!
ridgewoodreno
in Brownstoner Renovation 11 years and 5 months ago
ridgewoodreno | 11 years and 5 months ago
object(WP_User)#4986 (8) {
object(stdClass)#4974 (12) {
string(6) "183506"
string(13) "ridgewoodreno"
string(34) "$P$B321auxerN3M0OcUDLWr3iJKYXIX3b."
string(25) "lynne_polvino@hotmail.com"
string(19) "2017-08-10 13:55:18"
int(183506)
Many thanks for all the advice and suggestions! Yes, the box is off-center, and he plastered over part of the ornate detail. We’ve been very clear from the start that we value and want to preserve the home’s original features, but he just doesn’t get it, unfortunately. (He keeps trying to convince us to remove the pressed-tin ceilings and install pot lights, and to carpet over the parquet floor!) We’re looking for another contractor to renovate the rest of the building after he finishes the work he’s doing on the rental unit. Recommendations welcome!
brklyn1 | 11 years and 5 months ago
object(WP_User)#4985 (8) {
object(stdClass)#4984 (12) {
string(6) "177008"
string(7) "brklyn1"
string(34) "$P$BQam9e4lWMyPsTKHXSLX.5acWfaknt."
string(7) "brklyn1"
string(22) "Orientedcorp@gmail.com"
string(27) "http://Www.orientedcorp.com"
string(7) "brklyn1"
int(177008)
The box is of centre and it will be noticeable. And that messes up the whole thing. You can make a mold to look exactly, remove the existing And center it with the light box. But the problem is the cost. Which might be $500\.
daveinbedstuy | 11 years and 5 months ago
object(WP_User)#4974 (8) {
object(stdClass)#4981 (12) {
I would cut out the whole center portion and replace it, leaving the outer ring of acanthus leaves. You should be able to find a suitable replacement piece in that diameter from MANY places online, either plaster or plastic. The plastic would be better as it is lighter and using a canopy like recommended above would holdit in place after you plastered the edges to meet the existing medallion. Yes, be did a poor job. There seems to be a lot of that quality workmanship around and it’s inexcusable. Is the box off-center? A bigger problem.
rh | 11 years and 5 months ago
string(4) "3878"
string(2) "rh"
string(2) "rh"
string(2) "rh"
int(3878)
If you enlarge the photo, you’ll see that there is flat plaster where there was ornate detail. Don’t know if he just plastered over the leaves or if he screwed them up and added flat plaster to close it in, but it looks pretty messed up. The door, the medallion and the tub. This guy doesn’t know what he’s doing.
cate | 11 years and 5 months ago
object(stdClass)#4988 (12) {
Although the fact that is off center is kind of worrying. I hope he is more careful with his other work. You don’t want things installed off center — such as outlets, light fixtures, medicine cabinets. Our electricians were very careful to align everything perfectly, such as lights over sinks.
object(WP_User)#4989 (8) {
I don’t see damage. The medallion is in good shape, and he enlarged the hole to get a current code electrical box in there. He did a good job. Although it is unfortunately off center. Almost any electrical fixture will cover the hole. As Bob says, one with a canopy for covering a gas pipe will certainly do the trick. If, because the hold is off center, a piece still peeks out, I would think you could slap a little wire mesh with plaster on it up there and no one will ever notice.
Arkady | 11 years and 5 months ago
object(stdClass)#4991 (12) {
This was on the Forum a while ago: http://brownstoner.staging.wpengine.com/forums/topic/recommendations-for-fixing-detailed-ornate-plaster-work-in-vestibule/#replies
BobMarvin | 11 years and 5 months ago
object(WP_User)#4990 (8) {
object(stdClass)#4985 (12) {
You might be able to cover that entire hole if you use an antique (or repro) deep canopy on your light fixture. Something like this: http://www.antiquelampsupply.com/images/products/lg/11816A.jpg or this: https://img1.etsystatic.com/043/0/6497699/il_340x270.643159077_rlsp.jpg
object(WP_User)#4992 (8) {
string(6) "183506"
int(183506)
Photo now attached!
