NEST thermostat
I have a ten volt exsisting boiler, and I would like to upgrade to a NEST thermostat. The NEST requires 24 volt power, can anyone refer us to someone that can add a transformer to our system? We would really like to use the NEST thermostat.
anetwest
in Brownstoner Renovation 13 years and 4 months ago
Master Plvmber | 13 years and 4 months ago
object(WP_User)#4969 (8) {
object(stdClass)#5036 (12) {
Ok. I’ve never heard of a 10-volt thermostat. Are you sure? In some advanced systems, there are zero-to-ten-volt DC modulating thermostats, which you don’t have. You may also have a millivolt (mV) thermostat, but the boiler would also have to run on mV. Check it out.
anetwest | 13 years and 4 months ago
object(WP_User)#5012 (8) {
object(stdClass)#5013 (12) {
string(6) "178615"
string(8) "anetwest"
string(34) "$P$BAmK9SXh1kDYHAVpZQL876SDgNM3611"
string(18) "anetwest@gmail.com"
string(23) "/forums/users/anetwest/"
string(20) "L9wFK2KDLZDZMMMLajSi"
int(178615)
Oh, no it is the current thermostat that is 10 volt, and the NEST needs 24 volts. How do we add a transformer?
object(WP_User)#5016 (8) {
object(stdClass)#4974 (12) {
I’ve never heard of a 10-volt boiler. Are you sure?
