Mediocre renovation work, what to be on the lookout for
The whole point of flipping is to do the least amount of work for the highest profit. It’s main purpose is to conceal defects and provide a vaguely presentable snapshot to all parties involved in the selling process. The banks are more concerned with financial statements and the appraisers are probably scapegoats. This is the mentality as doing proper work becomes ever less affordable for the homeowner because doing proper work is a costly process. Consider a TV show comparison, This Old House vs. Flip or Flop.
zag0r
in Brownstoner Renovation 10 years and 10 months ago
23
murbard | 10 years and 10 months ago
object(WP_User)#5195 (8) {
  object(stdClass)#5024 (12) {
    string(6) "185535"
    string(7) "murbard"
    string(34) "$P$B/x.UxlzryKwlVeh3MaWT6SG5W0jii."
    string(7) "murbard"
    string(25) "arthur.breitman@gmail.com"
    string(19) "2017-08-10 13:56:24"
    string(7) "murbard"
  int(185535)
Hi all, I am looking at a brownstone in the Bed Stuy area that’s currently being renovated. It is not a gut renovation, as the place seems to have been in good condition before. The agent says that the electrical and plumbing have been fully redone. However, the work being done is clearly shoddy. There are exposed pipes, some of which have been clumsily boxed, leaving an interstice between the box and the wall for dirt and crud to accumulate in. They’ve installed floor radiators which are eyesores, the pipes go through the floor without pipe flanges (though perhaps they intend on installing those later?). Old, wooden, indoors, window shutters have been glued to the wall and daubed with a thick coat of paint instead of being removed or replaced. The shutter is glued at an angle, leaving about 100 cubic inches of space between the wall and the shutter – and, why, no, of course they did not bother to paint between the shutter and the wall, I mean, “whatever”, right? I’m trying not to let that influence me too much. Even though doing mediocre work like this is a shame and a waste of money, it doesn’t mean it can’t be fixed by another contractor. But… 1) What type of cost am I looking at to correct those issues? 2) More importantly, what do they tell me about bigger ticket items, what should I be on the lookout for? Since they seem to be cutting corners, I worry that – they might only have changed the sockets instead of putting in new wires (even though they said they redid the entire electrical) – they might have left some old plumbing pipes in place – they might not have bothered checking the joists and masonry
daveinbedstuy | 10 years and 10 months ago
object(WP_User)#5193 (8) {
  object(stdClass)#5192 (12) {
You need to use a competent inspector to answer most of these questions. Your initial concern is probably correct though and there are likely more important corners cut that you aren’t seeing. Something that you could do is check for an updated circuit breaker panel and how many circuits there are. Also, are all the wires emanating from those circuits new Romex plastic covered, BX metal”cable” or older looking fraying plastic/cloth covered. If you make an offer, you can always have that null and void based on your inspector’s report. You also need a good BROOKLYN based real estate lawyer for this process.
catboot | 10 years and 10 months ago
object(WP_User)#5031 (8) {
  object(stdClass)#5194 (12) {
    string(5) "56593"
    string(7) "catboot"
    string(7) "catboot"
    string(49) "http://bstoner.wpengine.com/forums/users/catboot/"
    string(7) "catboot"
  int(56593)
While I don’t doubt the work is shoddy (a lot of flips are), exposed radiator pipes are not unusual in a brownstone. The painted over shutters are also a common thing – my guess is that they were just left as they were. It’s not hard to fix, just time consuming. If the work that has been looks to be of poor quality, I would be concerned about the what lurks behind the walls. Did they pull permits for the electrical and plumbing work? You can check the DOB website to see if they did. That is the stuff that is expensive to fix and can cause huge headaches later on. As daveinbedstuy said, get a competent inspector and ask lots of questions.
  object(stdClass)#5196 (12) {
    string(6) "185535"
    string(7) "murbard"
    string(7) "murbard"
    string(7) "murbard"
  int(185535)
Hum, the DOB doesn’t mention any electrical application. I see some plumbing slips from January with no details, and a $5000 work in February for changing bathtubs, sinks & toilets. Maybe the slips from January are for the whole plumbing, but there’s no detail? Not sure how to interpret that, it seems bad, but I’ve also checked a nearby building which has been gorgeously, expertly gut-renovated, and I see no electrical application either, and just “plumbing slips”. I guess the engineer will have to figure all this out.
  object(stdClass)#5197 (12) {
    string(5) "56593"
    string(7) "catboot"
    string(7) "catboot"
    string(7) "catboot"
  int(56593)
if the house was properly maintained before the flippers got it, there may be no cause for alarm, and the work was just to fix what needed to be fixing. But if they are claiming that the electric and plumbing has been fully redone, I would hope there is a paper trail. A lot of flippers don’t pull permits, or pull incomplete permits. Ultimately you have to trust your gut. If these guys seem fishy and the work is questionable, walk away. If you really love the house, get a really good inspector and see what he finds. But remember that the inspection can only tell you so much, and can only inspect what he can see. During our search, we saw some really horrible work (and I’m sure it’s much worse now)
object(WP_User)#5196 (8) {
  object(stdClass)#5031 (12) {
    string(6) "185535"
    string(7) "murbard"
    string(7) "murbard"
    string(7) "murbard"
  int(185535)
Thanks. Any tips on how / where to find a good inspector?
object(WP_User)#5197 (8) {
  object(stdClass)#5195 (12) {
Richard Parry (sp?) did the inspection for my buyers. He was quite thorough and professional Here’s another recommendation from the archives here… I used richard perri based on some glowing rec’s here and had a very good experience… I had a carbon copy of his notes on the day of inspection and a detailed type-written report within the week following. he’s not cheap, but I thought he was well worth it. 718-828-9116
  object(stdClass)#5193 (12) {
    string(5) "56593"
    string(7) "catboot"
    string(7) "catboot"
    string(7) "catboot"
  int(56593)
I believe there is a thread about that in the archives. We used Matthew Wynne of Aberdeen Building Consulting. He was super thorough and spent quite a long time talking to us after the inspection and going over everything. We still use us the report as a reference, 3 years later. http://aberdeenbuildingconsulting.com Search the forum and more recommendations should pop up
cate | 10 years and 10 months ago
The three examples you mention are minor details. An inspector will focus on the crucial and expensive systems such as structure, roof, leaks, boiler, plumbing, and electrical. If they say the electrical and plumbing are all new, I’d want proof, permits, and to see that it was installed by licensed people and to code. A carpenter could fix the boxes and shutters for you, though some of it might be tedious and relatively expensive. Sounds like the walls are not straight. Also, generally speaking, when inspecting a house I’d want to see a dry basement, preferably with original walls exposed and not covered by Sheetrock, and level floors.
dorkofwindsor | 10 years and 10 months ago
  object(stdClass)#5198 (12) {
I bought a flip with no electrical permit. Guess what – it wasn’t done to code. I have already re-run some circuits. If the walls are drywall, its easier to fix things. If plaster, you’re a little screwed without bigger work. If i were you, i would first request from the agent that you are serious but need to verify with plumber and electrician the work done. If they are not good with you calling, it is a bit of a warning sign. This happened to me, i was not allowed to contact the GC who did my reno and they (finally!) admitted that it “ended badly”. I got a deal and low balled in a bad market, but i’ve still done some major re-work. If it was in a hot market, i would have been ignored and the it would have been bid up more than it deserved. Just do your due diligence.
slopefarm | 10 years and 10 months ago
  object(stdClass)#5199 (12) {
    string(3) "655"
    string(9) "slopefarm"
  int(655)
the real problem is that the price will reflect renovation when you are going to incur the costs of re-renovating. Not ideal. If they are cutting corners on the stuff that is visible, they are likely cutting bigger corners on the stuff you can’t see. As my grandmother would say, I know from whence I speak. Richard Perri is a great recommendation for an inspector, but he can’t see behind the walls. Start with the mechanicals in the basement — is the basement ceiling sheetrocked? that would be a sign that they are hiding conditions — water damage, crappy plumbing or electrical, etc. You want to vet this for the right electrical — wiring is balanced, there is sufficient amperage, outlets to code in every room, etc. My gut tells me to stay away from this one unless you can get it at a price that accommodates a full reno by you, but if you must try to have it, kick the tires really, really hard.
NeoGrec | 10 years and 10 months ago
  object(stdClass)#5200 (12) {
    string(4) "1741"
    string(7) "NeoGrec"
    string(7) "neogrec"
    string(7) "NeoGrec"
  int(1741)
In my experience there are very few really thorough, demanding inspectors out there. Most just want to take a quick look, write a prefunctory report and collect their fee. I think “Richard Parry” who Dave mentions is actually Richard Perri: 718.828.9116; phi@richperri.com. He knows his stuff but be ready to ask a LOT of questions. Oh, the other thing to mention is that many of the issues you’re describing are the fussy, labor-intensive skilled tasks that many GCs can’t be bothered with. They cost a lot to get right (wood stripping, precise finish carpentry, plaster skim coating, well-thought out placement of outlets and light fixtures, door hardware etc.) but they will make all the difference to the quality of the finishes in your home and your experience of living there.
  object(stdClass)#5201 (12) {
    string(6) "185535"
    string(7) "murbard"
    string(7) "murbard"
    string(7) "murbard"
  int(185535)
Thanks all for the comments. I took some pictures of the basement and the cellar (not certain which you mean) and in both cases the ceiling is, hum painted white, like the wall. So I’m not sure if it’s sheetrocked or not (not very familiar with this). Something looks a little off with the cellar ceiling… the cellar walls are bricks, but the cellar ceiling doesn’t make a very neat angle with it, there seems to be an interstice. I’m definitely going to pay close attention to that. @NeoGrec: Yes! Smart outlet placement is so important, thank you! Do you have a rough estimate of the cost of such finishes, for a 3,000 sq feet home?
  object(stdClass)#5202 (12) {
    string(3) "655"
  int(655)
Whether it is sheetrock or something else, if the cellar is just storage and mechanicals, i’d want to see the joists and mechanicals. If they threw up a ceiling, I’d be suspicious they are hiding conditions they do not want you to see.
Arkady | 10 years and 10 months ago
object(WP_User)#5201 (8) {
Slopey – I think it’s a law that a ceiling has to be ‘rocked if there’s a dwelling above.
object(WP_User)#5202 (8) {
    string(5) "56593"
    string(7) "catboot"
    string(7) "catboot"
    string(7) "catboot"
  int(56593)
It’s good that you are asking questions and being diligent about what you’re buying. Since it seems that you’re somewhat unfamiliar with some of the common issues with brownstones, I feel I should give you a heads up: renovated or not, old houses have problems, and it’s not unusual to start fixing something and end up fixing 12 other things that were triggered by that first that needed fixing in the first place. I wouldn’t dream of trading our 120-year old house for a newly built one, but it’s not headache-free living. If this is the first place you’re buying where you are fully responsible to the upkeep, without the benefit of a super or a landlord, keep in mind that this is what you’re signing up for. In my opinion nothing beats the character of an old house, but it will, on occasion, test your patience and your bank account.
  object(stdClass)#5203 (12) {
…..and your bank account….. assuming slope farm meant a freshly rocked ceiling intended for purpose of coverup, which this seems to not be the case.
Sounds like the cellar is original, not covered up. Our cellar had original plaster ceilings. But if they really did a whole-house electrical upgrade, pretty sure you’re going to see some big ol’ holes punched in that ceiling! Maybe they were very neat and cleaned it up (ha). Your inspector will be able to tell you if the entire electrical system has been upgraded, and if the placement of outlets is to code, although he can’t see through walls and see if they cut corners there (by not using BX cable throughout, for example).
brucef | 10 years and 10 months ago
object(WP_User)#5203 (8) {
    string(4) "4724"
    string(6) "brucef"
    string(6) "brucef"
    string(6) "brucef"
  int(4724)
Sorry for the late reply, but I have x-ray vision and can see the problems from 100 miles away. Tomorrow morning I have electrical inspection 7:30 AM, and we were in excellent shape before flunking our initial inspection. SO if you are thinking it won’t be so hard to fix again later, you are mistaken. They are flat out lying about having done the electrical. Yes, their sloppy guy who knows a little about wiring up a flip did add some unlicensed circuits, and connected up some old runs, but all that will be trash if you (or whoever) buys this disaster in the making. Without digressing to plumbing and heating, brownstoners need to be aware of an underlying fact. Once your house is ruined by hacks, you can never go forward legally. You will be forced into a “nether” world of future illegal work. And let me tell you your pot of gold at the rainbow won’t be waiting for you. You’re probably thinking that x number of years from now my house will be worth xxxx dollars and someone will want to buy it and I will cash out. You are half right. You will only be able to sell as a shell (reduced pricing) because your buyer will have a bank in the picture, and the bank won’t go for your illegal improvements. The same folks who would be willing to pay top dollar are in general somewhat clever. Sure you might find a buyer who doesn’t check and pays cash. If you haven’t spent time actually getting jobs approved at DOB, you haven’t a clue what truly goes on. DOB is geared to true gut renovations (think condos) or new construction. A reasonable person might assume that the DOB is reasonable, but it ain’t so. They have an unfortunate bias against restoration and renovation. You can huff and puff about how preserving perfectly good features from the past are worth re-using, but they aren’t interested. So how does this all relate to your prospective purchase? Less headache if you buy the shell and properly renovate. paying for a flipper’s shoddy work is a waste. It screws you in the future because any future approval will NOT GRANDFATHER their illegal work. Feel better now Green Mountain?
