Looking to replace a banister in a mix use brownstone.
The current wood banister is thin and from years of abuse from tenants moving in and out, the banister has become wobbly. I was thinking of replacing it with something like this: http://www.superiorconcretecompany.com/Beck_Stairs.jpg Does anyone have any recommendations for another style for a mix use brownstone? Anyone know who I can get to create this? Estimated cost? Thank you
landlord
in Brownstoner Renovation 12 years and 2 months ago
cate | 12 years and 2 months ago
object(WP_User)#5060 (8) {
  object(stdClass)#5004 (12) {
Or maybe you have a metal staircase with a wood banister. I would get a free quote from a couple of stair specialists first. They have all the right parts to replace a wood banister with exactly the same thing.
object(WP_User)#5058 (8) {
  object(stdClass)#5061 (12) {
Does the building have its original 19th century staircase or is this newer? If you call a stair specialist (there are several listed on this site) they can replace or fix the existing banister at relatively little cost. The problem also may not be with the actual banister — the stair could be pulling away from the wall and causing the banister to come loose. If you are looking to add a heavy duty modern banister like the one in the photo onto an existing 19th century original wood stair, that might not be the best idea. It will be very expensive to custom fabricate to fit and the connection and structure may not be the sturdiest. You could replace the entire stair altogether with a new modern one. This would also be extremely expensive. I lived in a building where the landlord had done this and the stair didn’t fit exactly as it should in the space, and the new staircase blocked all the light coming from the skylight in the roof.
fkeels1973 | 12 years and 2 months ago
object(WP_User)#5059 (8) {
  object(stdClass)#5062 (12) {
    string(6) "209452"
    string(10) "fkeels1973"
    string(34) "$P$BEhMdlkGh2Zixj2BpX4lB7aH4ZJjK01"
    string(17) "keelsfa@gmail.com"
    string(19) "2024-06-29 14:33:06"
  int(209452)
I recently did a similar project in one of my tenant units (see the picture). I hired a gentleman named Simon Chiu. He was very pleasant to work with and he built exactly what I requested. He used 1×2 stainless steel stock for posts and 1/2 x 1″ stock for the horizontal members. The railings turned out beautifully. There’s supposed to be a white oak rail on top, which I planned to do myself, but I haven’t gotten around to it. I highly recommend Simon for the quality of his work. And his crew left the place spotless which I appreciated. I can’t recall the price but it was reasonable. The only drawback is that his English is not great, so communication can be tricky. Anyway, he did a great job and I would do business with him again. His number is 917 650 5012\. Good luck!
landlord | 12 years and 2 months ago
object(WP_User)#5061 (8) {
  object(stdClass)#5060 (12) {
    string(5) "10735"
    string(8) "landlord"
  int(10735)
…Thanks snowman
snowman2 | 12 years and 2 months ago
  object(stdClass)#5063 (12) {
    string(5) "44724"
    string(8) "snowman2"
  int(44724)
asia-2010 is a shill for Anthony
metalwork | 12 years and 2 months ago
  object(stdClass)#5059 (12) {
    string(6) "181255"
    string(9) "metalwork"
  int(181255)
coresolutionsnyc@gmail.com.
