Crack in the plaster ceiling
Two years ago we redid our upstairs bathroom, adding a clawfoot tub. We have just noticed that what was a small crack in the parlor ceiling (below the bathroom) has gotten much more significant. Before we all come crashing down, can any one recommend a good structural engineer to have a look? Thank you.
libertyh
in Brownstoner Renovation 11 years and 5 months ago
brucef | 11 years and 5 months ago
object(WP_User)#5043 (8) {
  object(stdClass)#5031 (12) {
    string(4) "4724"
    string(6) "brucef"
    string(6) "brucef"
    string(6) "brucef"
  int(4724)
Yes, a contractor who will demo enough to find the underlying problem. Tell him he is not there to fix the crack, but to fix what caused the crack. After wards the crack may be patched.
libertyh | 11 years and 5 months ago
object(WP_User)#5042 (8) {
  object(stdClass)#5041 (12) {
    string(6) "183556"
    string(8) "libertyh"
    string(34) "$P$Bfljk1hJvd7flEzG1bvikPaqy9kqC81"
    string(24) "liberty.howell@gmail.com"
    string(19) "2017-08-10 13:55:20"
  int(183556)
Who then should I call for such a thing? A contractor? Thanks again.
object(WP_User)#5038 (8) {
  object(stdClass)#5044 (12) {
    string(4) "4724"
    string(6) "brucef"
    string(6) "brucef"
    string(6) "brucef"
  int(4724)
You don’t want a structural engineer. Check previous posts/rants of mine, I don’t feel like getting all riled up right now. You won’t know what is going on until you open the ceiling and visually inspect. 99% of the time it is something local and obvious, like a butchered beam that needs to be reinforced. It needs to be fixed, so don’t spend double just to get an opinion from an structural engineer who wouldn’t know a fix if it bit him.
object(WP_User)#5041 (8) {
  object(stdClass)#5043 (12) {
    string(6) "183556"
  int(183556)
Here’s the photo
object(WP_User)#5044 (8) {
  object(stdClass)#5042 (12) {
    string(6) "183556"
  int(183556)
Thanks for the replies. I’ve attached a photo, which doesn’t look like much, but my concern is that it’s gotten much longer recently. Thank you!
Springs | 11 years and 5 months ago
  object(stdClass)#5038 (12) {
    string(5) "13117"
    string(7) "Springs"
    string(34) "$P$BTLknXuobfkPdh2APXje29kDjduYU8/"
    string(7) "Springs"
    string(21) "jamie.grubb@gmail.com"
    string(19) "2008-07-16 03:51:12"
    string(7) "Springs"
  int(13117)
Can you post a picture ? Structural engineer is most likely not the right person to look at it.
no-permits | 11 years and 5 months ago
    string(6) "176811"
    string(10) "no-permits"
    string(16) "c90027@gmail.com"
  int(176811)
a small crack sounds cosmetic. put a level on the tile/ceiling before you do something extreme like call a structural engineer who will probably have a good laugh at your expense.
