Code for building metal deck -- please help!!
We are changing the CofO in a brownstone from a 6 to a 2 family and are building a deck — so need to make sure the deck meets code. If it is metal — can it be right against the property line or does it need to be at least 3 feet away? Below is the link to the code and the two conflicting parts. Please help!! Thanks so much in advance! http://www.nyc.gov/html/dob/downloads/pdf/tool_kit_pools.pdf NYC Zoning Resolution and NYC DOB TPPN 4/03 • Distances to Property Lines: At least 3 feet between the sides of the deck or porch and the property line • Materials: Combustible materials, such as wood, are not permitted within 3 feet of lot lines or in multiple dwelling buildings.
lz26
in Brownstoner Renovation 11 years ago
curated | 11 years ago
object(WP_User)#4980 (8) {
object(stdClass)#5053 (12) {
string(6) "176931"
string(7) "curated"
string(7) "curated"
string(15) "c@curatedny.com"
string(7) "curated"
int(176931)
This is something that your architect should be able to determine as it pertains to your particular lot. http://brownstoner.staging.wpengine.com/curated
daveinbedstuy | 11 years ago
object(WP_User)#4979 (8) {
object(stdClass)#4978 (12) {
Bessie, your second point is wrong. In general, it depends upon lot length and proximity of the rear of the building to the rear lot line.
Bessie | 11 years ago
object(WP_User)#4975 (8) {
object(stdClass)#4981 (12) {
string(4) "6998"
string(6) "Bessie"
string(34) "$P$BGSC3nCd7fZ2thUAg.nOtWpKwRzNED0"
string(6) "bessie"
string(20) "lboyes@aging.nyc.gov"
string(19) "2017-08-10 13:46:17"
string(6) "Bessie"
int(6998)
3′
object(stdClass)#4982 (12) {
string(4) "6998"
string(6) "Bessie"
string(6) "bessie"
string(6) "Bessie"
int(6998)
http://www.nyc.gov/html/dob/downloads/pdf/tppn0403.pdf The bulletin clarified the earlier info. A non-combustible deck can be built closer than 3″ to the property lines. In general the projection into the rear yard should be less than 8′.
zag0r | 11 years ago
object(stdClass)#4983 (12) {
string(6) "184861"
string(5) "zag0r"
string(34) "$P$B8NqdTV5KbklXy8yLVw6i9FMhe3X5Y."
string(5) "zag0r"
string(21) "ah_yaaak@hushmail.com"
string(5) "zag0r"
int(184861)
Your architect can provide an answer that conforms to your particular lot.
