Brownstoner Shutters
We are looking to add traditional wooden shutters to our Park Slope brownstone.  Bay style windows – we’d like to get split top/bottom so that we can have light coming in while maintaining privacy.  Any ideas where to start; pricing etc.?  Open to rehabbing or purchasing new. Thanks in advance.
Seblicious
in Brownstoner Renovation 14 years and 6 months ago
devenco | 13 years and 11 months ago
object(WP_User)#4963 (8) {
  object(stdClass)#5030 (12) {
    string(6) "179015"
    string(7) "devenco"
    string(34) "$P$BIbJNm6gWzfImH4cIpeH3LbTSP5ZNj."
    string(7) "devenco"
    string(23) "Wayne@shutterblinds.com"
    string(48) "http://www.brownstoner.com/forums/users/devenco/"
    string(19) "2017-08-10 14:38:05"
    string(7) "devenco"
  int(179015)
How to Install
Brownstone
Pocket Shutters
http://www.shutterblinds.com/NewStart/images/littlebigfront.gif
We offer a color brochure
and product order form,
http://www.shutterblinds.com/NewStart/images/brochA.gif
as well as the
How to Measure and
Install pamphlet.
****No automated PhoneMenus.
Our knowledgeable staff is available
Monday – Friday,
9 AM – 5 PM
**P. 800-269-5697
P. 404-377-0306
F. 404-377-1120**
P.O. BOX 322
Avondale Estates, GA
30002
http://www.shutterblinds.com/images/facebook.jpg
https://sealserver.trustwave.com/seal_image.php?customerId=79dbb7a00ca511e0b34b005056b201e5&size=105×54&style=
** **What are Brownstone pocket shutters?** Pocket shutters, formally known as embrasured shutters, are common to Brownstone townhouses. This unique architecture from the mid 1800’s is seen in the Brownstones of Brooklyn, Back Bay, Boston, Baltimore and other east coast cities of the period. Many of these Brownstone Townhouses came originally with pocket shutters which folded neatly into their own pocket built into the window jamb. The craftsmen of the day took great care to build out the windows jambs to receive the shutters so as to show off the ornate casework and moldings, the notion being that a window with disappearing shutters would not need heavy draperies covering the millwork and window casing. Over the years this unique shutter design has assumed the name of Brownstone Pocket Shutters. Through the years the shutters in these homes have often been discarded leaving the windows bare and in need of replacements. In replacing the shutters to fit within the existing pockets, care must be taken in order to achieve a perfect fit not only across the window but also within the pockets. So the shutters must function perfectly within two perpendicular planes. **Types of window jambs** There are three primary jamb designs with pocket shutters. **1)** First and most common is the square jamb with embrasures; four shutter panels across the window, a pair bi-folding to each side and into the pockets.
http://www.shutterblinds.com/Coreys/Animation2.gif
**2)** Additionally one will find the splayed jamb embrasures in which the jambs and pockets angle outwards thus allowing a wider shutter to fit within the thickness of the wall. Again four panels across the window, a pair bi-folding into the respective pockets on each side. **3)** Finally there is the twin window, this is to say two windows that are mounted side by side. In this case the shutters are often installed to each outside jamb generally with the use of three shutter panels hinging across each window and tri-folding into the respective pockets. **Shutter design** Brownstone shutters are comprised of solid raised panels and operable louvered panels generally installed in double hung fashion, meaning a set of four shutter panels hinged at the top and four panels hinged at the bottom allowing the top shutters to hinge open separately from the bottom shutters. There are different designs but this is most common.
http://www.shutterblinds.com/Coreys/poc_big.gif
http://www.shutterblinds.com/Coreys/empty.gif
**Intent of the tradesman ** The intent of pocket shutters is of course to cover the window for privacy and protect from the damaging rays of the sun while adding additional millwork to the interior of the house. Additionally shutters offer a measure of insulation from the cold in the winter. When the shutters are open, i.e. folded into the pockets, the flank shutter panel which is the raised panel appears to be the interior jamb of the window. Typically when the shutter is closed across the window the back of the pocket may reveal an identical raised panel. This cleaver carpentry was very popular in masonry buildings from the early 1850’s through the early 1900’s, though it is seen much earlier in Virginia and New England and earlier still in Europe. Monticello, the beloved home of Thomas Jefferson has embrasured shutters installed throughout the main lever of the house. **Installing Pocket shutters** If you have existing pockets, half of the work is done. The overall width of the shutters must match the width of the pockets on the front of the jamb (see D on diagram below). This is the near side of the pocket directly behind the window casing. From this dimension you must deduct the diameter of the barrel of the hinge on each side and allow perhaps 1/8″ additional clearance. The flank panel (solid raised panel) must be as wide as the pocket is deep (B). Again deduct the diameter of the barrel of the hinge and allow an additional 1/8″ for clearance. The two inner panels must total the remainder of the width of the window. The flank panels must be rabbetted in mirror image to one another with the long side of the rabbet fitting on the near side of the pocket. (See cross section Diagram). A stop should be added to the inside of the pocket to allow the shutters to close into the pocket exactly perpendicular to the window and meeting the inside edge if the window casing. The flank panels are hinged to the front (not inside) of the window jamb. This is actually the back of the pocket. The hinges are installed open face, barrel back. One leaf is attached to the outside beveled edge of the shutter, the other leaf is secured to the face of the jamb (the back of the pocket) The hinge should be mounted to the shutter first. The four shutters then should be centered in the window to assess the fit. The outside edge of the flank shutter should align perpendicularly with the front edge of the pocket. (refer to cross section diagram for details) The inner panel folds across on top of the flank panels. This means that the hinges must be surface mounted on the shutter stiles. (The inner panel hinges, in some cases, can be mortised between the panels however this requires a non-swaged hinge the thickness of the stile rabbets. This is not common practice) Generally each of the inner panels will measure at least 1 1/2″ narrower than its adjoining flank panel. These dimensions are dictated by the overall width of the window relative to the width of the pocket.
http://www.shutterblinds.com/Coreys/fold_measure2.gif
Craftsmen in the age or the Brownstone townhouses would know this craft well however those of the Twenty First century may be quite unfamiliar with the art. At Americana pocket shutters are common knowledge and a daily endeavor. We can manufacture replacement shutters that very nearly replicate the original shutters from 150 years ago. We can stain or paint your shutters to match the color specified by you or your designer. If your pockets no longer exist we can design new pockets and send drawings for your tradesman to work from, and then shutters to fit within. Call or email with your dimensions and a photo along with the necessary details, we will send a proposal the following day for the shutters as specified. Manufacture typically takes approximately 6 weeks but may vary based upon the species, design or the season of the year. Our plan is to replace all the shutters in all of the Brownstone Townhouses in America.   **Call Us: 800 269 5697**
gurv | 14 years ago
object(WP_User)#5006 (8) {
  object(stdClass)#5007 (12) {
    string(6) "179056"
    string(4) "gurv"
    string(34) "$P$BUdI4h50/TL8vJKk35XSalgym80Pic0"
    string(4) "gurv"
    string(21) "gurvdpfoc25@gmail.com"
    string(45) "http://www.brownstoner.com/forums/users/gurv/"
    string(19) "2017-08-10 14:38:11"
    string(4) "gurv"
  int(179056)
Very true..I can’t suggest you a store, but i will suggest you to buy shutters online..It will give you opportunity to choose from large option in lowest price.
Ted, http://www.tradeshutters.ie/window-blinds.html
josh | 14 years and 6 months ago
object(WP_User)#5010 (8) {
  object(stdClass)#4968 (12) {
    string(4) "9275"
    string(4) "josh"
    string(63) "$wp$2y$10$5t1OTeXlz.LyaXUgFchhKOi3gMVA6Hua2R0imsDlFuIXHS7RWr.2i"
    string(4) "josh"
    string(18) "josh@bodeganyc.com"
    string(45) "http://www.brownstoner.com/forums/users/josh/"
    string(19) "2017-08-10 14:19:47"
    string(4) "josh"
  int(9275)
The Demolition Depot in Harlem has 4 floors of salvaged goods and pretty good prices.  I haven’t been there personally but hear it’s worth a visit. -Josh Goldstein www.jgoldsteinarchitect.com
