Asbestos removal
Hi. I just bought a brownstone in bed-stuy. The Con Ed guy was over to wire up the meters; he looked around and said “you have asbestos here, I can’t work until you abate it”. I looked and it appears there is about 3 inches of asbestos insulation on one of the pipes coming out of the wall, with the end broken off. Does anyone have someone they recommend who can get this taken care of? Do we need to have the entire basement inspected now? I’ve read in other threads that for permitted work in a basement you often need an asbestos inspection; will taking care of this now suffice? Thanks.
whomever
in Brownstoner Renovation 11 years and 4 months ago
12
whomever | 11 years and 4 months ago
object(WP_User)#4990 (8) {
object(stdClass)#4978 (12) {
string(6) "184255"
string(8) "whomever"
string(34) "$P$BVCTq0N.BR31DcfRnQfBe9/1TomuOI1"
string(19) "mcrosby@marthon.org"
string(19) "2017-08-10 13:55:23"
int(184255)
So just as a followup, I ended up going with Leinster Contracting based on the recommendations. I heartily echo all the other recommendations: Super responsive and professional (only a few days between calling them and having the work completed), relatively affordable, came in exactly to the estimate. Now to deal with Con Ed, if only they were this good.
rh | 11 years and 4 months ago
object(WP_User)#4989 (8) {
object(stdClass)#4988 (12) {
string(4) "3878"
string(2) "rh"
string(2) "rh"
string(2) "rh"
int(3878)
If you’re gonna DIY, here’s an old post I wrote about safety precautions. http://reclaimedhome.com/2008/11/04/asbestos-yikes/
cate | 11 years and 4 months ago
object(WP_User)#4978 (8) {
object(stdClass)#4985 (12) {
Does the Con Ed guy or anyone else need to mess with it? Couldn’t you just cover it with something and leave it alone, so the particles aren’t released into the air?
no-permits | 11 years and 4 months ago
object(WP_User)#4991 (8) {
string(6) "176811"
string(10) "no-permits"
string(16) "c90027@gmail.com"
int(176811)
DIY if it’s a small amount. yes, it’s dangerous stuff, but you’re not working with it everyday. a one time exposure to it won’t harm you.
bk1lnite | 11 years and 4 months ago
string(6) "179741"
string(8) "bk1lnite"
int(179741)
What Dave said. Double bag it so it doesn’t leak in the trash. If money is no object, do it the right way hiring someone like Leinster or Asbestway. You’ll spend a relative fortune for guys to come in with hazmat suits and all their gear for 3 inches of stuff to get rid of.
dnk | 11 years and 4 months ago
object(stdClass)#4994 (12) {
string(5) "46107"
string(3) "dnk"
string(34) "$P$Bc/fuQ6M6AurKgSr2TPjNRasEkYaWi1"
string(3) "dnk"
string(28) "dkeegan@laskerfoundation.org"
string(18) "/forums/users/dnk/"
string(19) "2017-08-10 13:36:02"
string(3) "dnk"
int(46107)
I would not recommend that you remove it yourself. And it should be disposed of properly. Asbestos is a serious carcinogen, please take precautions so that you do not harm yourself or cause someone else (like the guy emptying your trash) to inhale asbestos particles. We had asbestos in our basement, and we used Leinster Contracting to remove and dispose of it. They were professional and efficient. 718-651-9100 Some other Brownstoner forum comments on Leinster: http://brownstoner.staging.wpengine.com/forums/topic/asbestos-removal/
daveinbedstuy | 11 years and 4 months ago
object(stdClass)#4995 (12) {
If that one portion of 3″ of asbestos is all you have, as you say, just wet it and remove it yourself, bag it and throw it away. Sounds like you had it in the past and it was removed except for that one piece, if that is the case.
Augustiner | 11 years and 4 months ago
object(stdClass)#4996 (12) {
You don’t need an inspection to know there is Asbestos. Just have it removed with the proper precautions. If you have an ancient Boiler, it will be around there too (boiler insulation, sealing compound)
brucef | 11 years and 4 months ago
object(stdClass)#4997 (12) {
string(4) "4724"
string(6) "brucef"
string(6) "brucef"
string(6) "brucef"
int(4724)
Call Mendy at Asbestway on Washington Ave. I sold him a building, and he’s done remediation for us.
housepoor | 11 years and 4 months ago
object(stdClass)#4998 (12) {
string(5) "71781"
string(9) "housepoor"
int(71781)
I recently had an inspection done by Joe Bova from Onsite Environmental. I though he did a great job and was priced reasonably. There was no remediation necessary and I am not sure he does that part. To get a DOB permit, you will need the inspection. (718) 234-7437\.
object(stdClass)#4999 (12) {
string(6) "184255"
int(184255)
I’m planning on redoing the kitchen. I do plan on redoing the stairs to the basement (current ones are a death trap), as well as some wiring and plumbing work.
carmenf | 11 years and 4 months ago
object(stdClass)#5000 (12) {
string(6) "183785"
string(7) "carmenf"
string(34) "$P$BrMmbYYBbygVsw3CwMFTT0MKyHkxrt/"
string(7) "carmenf"
string(28) "cristina.rasmussen@gmail.com"
string(7) "carmenf"
int(183785)
Are you planning on doing extensive work? You will likely need to get an asbestos inspection if you’re filing plans for any meaningful amount of work.
