Water feed valve leak issue from boiler
http://cdn.brownstoner.com/50eaf2ab5e234-.png
I am having an issue with small leaks from the boiler used in our building. The leaks seems to be coming from the air gap fitting of the backflow preventor (photo attached). Although the leaks are not severe (a few drips per day), i want to understand whether this is indicative of an issue requiring repair — or if it is ‘normal’ to see leaks stemming from the air gap fitting.  I am a novice so would appreciate any insight on this issue… thank you in advance!
jen1279
in Boiler Repair 13 years and 3 months ago
royalsmith | 13 years and 1 month ago
object(WP_User)#5096 (8) {
  object(stdClass)#5116 (12) {
    string(6) "177937"
    string(10) "royalsmith"
    string(34) "$P$BN3cftE1ACUvM5pjYvGmrPVMIyn407."
    string(21) "royal.smthi@gmail.com"
    string(51) "http://www.brownstoner.com/forums/users/royalsmith/"
    string(19) "2017-08-10 14:18:46"
  int(177937)
Hi, Firstly find cause of leaking.I want to share some possible cause of water leakage:Faulty pressure relief valve,Faulty  pump or Leaking water pipe connection.
steam_man | 13 years and 3 months ago
object(WP_User)#5097 (8) {
  object(stdClass)#5098 (12) {
    string(6) "176846"
    string(9) "steam_man"
  int(176846)
This is normal. That’s why it’s piped to a drain. Don’t worry.
