Thermostat Confusion or Perhaps Just Ignorance
I thought I had a 24 volt, 2 wire oil/steam heating system: my bolier is connected to my electrical system (it has its own circuit breaker). But, when I tried to replace my thermostat with a fancier 24 volt model, the new thermostat could not find any power. So could I have a millivolt system? My old thermostat, afterall, runs on batteries. But it seems, however, if my reading is correct that the millivolt would run off a pilot light (which my system does not have) via a thermocouple. At teh same time I have traced the wiring to the controls of the boiler & have not been able to identify a transformer One final piece of information, there is a third wire that isn’t used in the current setup. Is there a way to definitely tell if I have a 24 volt system? I appreciate any help..
hamiltonheights
in Boiler Repair 14 years and 2 months ago
northofditmas | 14 years and 2 months ago
object(WP_User)#5134 (8) {
object(stdClass)#5114 (12) {
string(5) "41958"
string(13) "northofditmas"
string(21) "olgierd@babypanda.org"
string(31) "/forums/users/limestone_cowboy/"
string(19) "2017-08-10 13:51:20"
int(41958)
There should be a transformer on the wall near your boiler (square metal block about 2″x2″ with two wires coming out of it). It might have 24V stamped on it somewhere. If not, for $15 you can get a multimeter and check it yourself. The same transformer could in theory be used to power the 3rd wire and your new thermostat. It would be cheaper to buy a battery operated thermostat than to hire a pro to rewire for you.
eman134 | 14 years and 2 months ago
object(WP_User)#5133 (8) {
object(stdClass)#5132 (12) {
you probably bought a three wire thermostat….your old stat was simply an on/off switch which needed it’s own power (batteries)…the wires were power in,power out, no common leg to power up the new stat
