Current Oil Heating Costs
Hi, I have been renting my home in Bed Stuy for the past 2 years. It’s 3 story brownstone mid-block with oil heating. The tenants seem to be burning through the heating costs as fast as I can fill up the tank. I had 200 gallons delivered on Jan 25th and just had to order another 200 gallons on Feb 5th after it ran dry. That’s a pretty crippling burn rate for heating costs. What type of heating costs are people seeing for comparable properties?
tommynotty
in Boiler Repair 13 years and 2 months ago
ellenlourie | 13 years and 2 months ago
object(WP_User)#5080 (8) {
object(stdClass)#5092 (12) {
why thermostat in the hallway? this not place for thermostat.
cate | 13 years and 2 months ago
object(WP_User)#5081 (8) {
object(stdClass)#5082 (12) {
Also we have the same issue w the heat either being on all the time or not going on. You have to play around until you find the perfect spot. Even so, some areas of the house will be a little colder at some times than others. Wear a sweater.
object(WP_User)#5079 (8) {
object(stdClass)#5078 (12) {
The problem is the thermostat setting, not oil vs. gas. Getting a programmable remote thermostat is a good idea. We have oil for heat and hot water and pay $300/month at 69 degrees. My neighbor pays the same for gas.
needmtg | 13 years and 2 months ago
object(WP_User)#5085 (8) {
object(stdClass)#5077 (12) {
string(5) "42472"
string(7) "needmtg"
string(7) "needmtg"
string(7) "needmtg"
int(42472)
Be aware that if have really creative tenants, a cube of ice near the ‘stat will turn the heat up to 90 ;). Try talking them into keeping the heat at a reasonable level.
tommynotty | 13 years and 2 months ago
object(WP_User)#5078 (8) {
object(stdClass)#5081 (12) {
string(3) "799"
string(10) "tommynotty"
string(17) "david@devlove.com"
string(21) "/forums/users/davebs/"
string(19) "2017-08-10 14:18:50"
int(799)
The thermostat is in the hallway so they can access it. We had problems with them constantly turning it up so we put a lockbox around it. The problem is that, we’d have problems getting it to fire up if the temp was set at 68 degress. One of our tenants just checked and its currently set to 75, which is pretty insane and I imagine its running 24/7\. I really need to get a thermostat I can monitor and control remotely. I was looking at the Nest but also Honeywell & Ecobee.
NeoGrec | 13 years and 2 months ago
object(stdClass)#5076 (12) {
string(4) "1741"
string(7) "NeoGrec"
string(7) "neogrec"
string(7) "NeoGrec"
int(1741)
We have a gas-fueled boiler and hot water heater. 4-storey, 2-family house. Thermostat set to 70 mornings and evenings (55 degrees during the day and overnight — but it rarely falls below 67). Annual cost of running ranges from $1,500 to $2,000\. We are always very clear with new tenants that if they want to run around in boxer shorts and tank tops in the middle of winter, this isn’t the place for them. Of course, they pay electric so they can always supplement with room heaters. Since their apt is the garden floor (lower ceilings), they’ve never complained. We also have new windows and weatherstrip all the doors.
SewardWasRight | 13 years and 2 months ago
object(stdClass)#5085 (12) {
string(5) "52609"
string(14) "SewardWasRight"
string(7) "usgrant"
string(7) "USGrant"
int(52609)
It sounds as though – unlike davidinbedstuy – that your tenants control the heat? If so, then they are going to keeep it on at all times – morning, noon and overnight. HPD regulates what the temperature needs to be for tenants and what it doesn’t have to be set at. Like run-joe, I’ve used only around 600-700 gallons since T’giving. I have a 4-story brownstone. First of all I would make sure that you somehow control the thermostat. Also, my oil cost has come down approx. 18-20% in the past year. Has anyone else nopticed this?
RunJoe | 13 years and 2 months ago
object(stdClass)#5075 (12) {
string(5) "25757"
string(6) "RunJoe"
string(22) "colonel-steve-austin-2"
string(16) "icdclcmc@aol.com"
string(22) "/forums/users/run-joe/"
string(19) "2017-08-17 21:41:42"
string(20) "MAdLwlb2ioHYS1BNdQov"
string(20) "Colonel Steve Austin"
int(25757)
I have a 5 story brownstone. From 1/15 to 1/26, I consumed 200 gallons also. That week was really really cold. Since Thanksgiving, I have consumed 750 gallons. I suspect gas folks might be in a bit of shock when they get their next bill.
object(stdClass)#5074 (12) {
install honeywell red link termostat system. it is far superior to nest.
daveinbedstuy | 13 years and 2 months ago
object(stdClass)#5073 (12) {
Convert to gas. I had a three storey with tenants on the ground floor. I controlled the thermostat. It was a very old gas forced air heating system. I kept it between 66 and 71 degrees. The combination of that and the gas hot water heater ran $1,700-1,900 A YEAR.
