chimney liner size for gas boiler
Hi there – any ideas what diameter liner I’ll need for a gas boiler in a 2 family, 4 story home? We just had a new liner put in for oil boiler + 2 gas hot water heaters – 10″ stainless steel (approved by DOB for dual-fuel). I’m hoping it’ll be sufficient for a gas boiler, too? Any thoughts?   Thanks!
empathie00
in Boiler Repair 13 years and 3 months ago
slvillager | 13 years and 3 months ago
object(WP_User)#5092 (8) {
  object(stdClass)#5120 (12) {
    string(4) "7086"
    string(10) "slvillager"
    string(5) "lucy7"
    string(21) "cfredericks@gmail.com"
    string(25) "/forums/users/slvillager/"
    string(19) "2017-08-10 14:20:52"
    string(5) "lucy7"
  int(7086)
call a chimney person to come look. we had a surprise with our oil to gas conversion where our basement filled with smoke and we had to do emergency relining. not fun at all.
empathie00 | 13 years and 3 months ago
object(WP_User)#5093 (8) {
  object(stdClass)#5094 (12) {
    string(6) "177582"
    string(10) "empathie00"
  int(177582)
Phew – great, thank you both very much! I don’t want to go through the chimney relining process (and cost!) again, so this is good news. 🙂
eman134 | 13 years and 3 months ago
object(WP_User)#5097 (8) {
  object(stdClass)#5091 (12) {
as long as the gas fired atmospheric vented boiler is approximately the same amount of btus (probably less) than the oil fired unit that you are replacing…no problem
Master Plvmber | 13 years and 3 months ago
object(WP_User)#5094 (8) {
  object(stdClass)#5092 (12) {
If it’s good for oil, it’s good for gas as long as both boilers are under 85% efficient.
