Stair Contractor?
I need a stair contractor for condo combination project. Have had little luck getting any kind of reply – anyone have suggestions here. Also – anyone with expertise here know cost differential of  building and installing a central steel tube stringer vs conventional open box double wood stringer?
bbmarket
in Architectural Salvage 13 years and 4 months ago
slopeneighbor | 13 years and 4 months ago
object(WP_User)#4997 (8) {
  object(stdClass)#5051 (12) {
    string(5) "22717"
    string(13) "slopeneighbor"
    string(34) "$P$BTGUJ7Q9cAHYaXZ9DjBgeWu8Fza9V9."
    string(29) "catherine.n.sheehan@gmail.com"
    string(31) "http:///forums/users/slopester/"
    string(19) "2017-08-10 13:46:14"
  int(22717)
I also had a great experience with Soxco and recommend them hands down.  Antoon is a master and his crew were a pleasure to have working in my home.
rustydevon | 13 years and 4 months ago
object(WP_User)#4998 (8) {
  object(stdClass)#4999 (12) {
    string(5) "32496"
    string(10) "rustydevon"
    string(34) "$P$BOftAzrUH1026WyyMo9yi7FLINMQLR/"
    string(21) "devon@nomdeguerre.net"
    string(25) "/forums/users/rustydevon/"
    string(19) "2017-08-10 13:48:14"
  int(32496)
Soxco Stairs just finished our staircases. If you are restoring a historic home I cannot recommend them highly enough. I believe they advertise here. Hands down the best sub I could recomend in general. PM me if you need more info.
cm | 13 years and 4 months ago
object(WP_User)#5003 (8) {
  object(stdClass)#4996 (12) {
    string(3) "665"
    string(2) "cm"
    string(34) "$P$BswWLA.pKLv0d5CgHKQvWAVovFV4kC/"
    string(4) "cm-2"
    string(22) "cmorisi@spitzereng.com"
    string(17) "/forums/users/cm/"
    string(2) "cm"
  int(665)
http://www.neandws.com/ NE&WS Stair in Maspeth. They can do either wood or metal.
goh | 13 years and 4 months ago
  object(stdClass)#4995 (12) {
    string(5) "34440"
    string(3) "goh"
    string(3) "goh"
    string(20) "gohsiew@yahoo.com.sg"
    string(44) "http://www.brownstoner.com/forums/users/goh/"
    string(19) "2009-07-14 11:10:41"
    string(3) "goh"
  int(34440)
Hello, If you live in a brownstone, a ballpark estimate for a center stringer steel stair may run between 25-45K, you’ll most likely have to reinforce the floor with steel beams at the top and bottom.  A double wood stringer stair may run between 10-20K and may require sistering joist at the top and bottom.  There would also be other cost involved, filing, GC, professional services.  I can recommend some GC’s for the job.   Garner Oh, RA goh@0-to-1.com www.0-to-1.com
