Water damage on Parquet Floor
I had a bathtub leak over the holiday and need to have my floor repaired. Would appreciate any advise. Has anyone used Stafford Eliott recently? Wondering if I should place something heavy on it so it flattens out….but I am afraid of breaking the boards. thanks.
dancingal
in About Brooklyn 11 years and 5 months ago
8
dancingal | 11 years and 5 months ago
object(WP_User)#5389 (8) {
object(stdClass)#5377 (12) {
string(6) "181041"
string(9) "dancingal"
string(34) "$P$B7rN.TgDnmtQit7F7gh3W2owfL4cAC."
string(21) "info@dalefournier.com"
string(19) "2017-08-10 14:07:35"
int(181041)
Great many thanks!
object(WP_User)#5388 (8) {
object(stdClass)#5387 (12) {
string(6) "181041"
int(181041)
Thank you Alfred, I greatly appreciate your advise!
alfredsutton | 11 years and 5 months ago
object(WP_User)#5377 (8) {
object(stdClass)#5384 (12) {
string(6) "184655"
string(12) "alfredsutton"
string(34) "$P$BPHD9bL5ku7.AKv6SjOI3FChBdq12H/"
string(24) "jasonbbrock905@gmail.com"
string(23) "http://atmplumbing.net/"
string(19) "2017-08-10 13:55:23"
int(184655)
I suggest that do not use very heavy fittings because it may damage the boards. i suggest that you should consult with your plumber once and if the plumbing is good I can guarantee there will be no leakage or seepage.
object(WP_User)#5387 (8) {
object(stdClass)#5389 (12) {
string(6) "184655"
int(184655)
Preventing hardwood floor water damage is a matter of immediately cleaning any spills that may occur. You can clean small spills with absorbent towels. Larger spills and outright floods require professional assistance to repair. Regardless of the source of the potential damage, you should use a combination of one or more dehumidifiers, fans, and open windows to maximize ventilation. A dehumidifier can remove a lot of moisture from the air, fans can expedite evaporation, and ventilation can help to balance the humidity in your home. You should avoid using heaters to dry a spill as a heater in proximity to damp wood often permanently damages it.
Guest User | 11 years and 5 months ago
Here is Jose Zambrano’s number: 917.355.7977\.
object(WP_User)#5391 (8) {
object(stdClass)#5392 (12) {
string(6) "181041"
int(181041)
Thank you for your reply Red Robin. The pieces are pretty stiff, don’t know about the steam, but I will ask..
cate | 11 years and 5 months ago
object(WP_User)#5393 (8) {
object(stdClass)#5394 (12) {
What stunning parquet. Would it be possible for a floor expert to straighten it out using steam?
Our parquet floor was damaged by water as well. Reached out to the forum and a number of people recommended Jose Zambrano (or Zombrano). He came over and will do the work for us after other renovations are done. He was great and very reasonable! The floor needs to dry out completely before any repairs can be made so I wouldn’t put anything on top of it because it could hold the moisture in. If you have a dehumidifier, run it. Based on what he’s going to do for us, he’ll likely have to replace the severely buckled pieces, but he keeps old stock. You can find his tel number if you search the forum archive. Or if I remember I’ll look for it tonight and post it.
