ISP in Sunset Park
Moving to Sunset Park in a week. Based on conversations with the landlord and real estate agent, I was under the impression that Time Warner was the ISP in my building. After getting the run around from TW, Verizon Fios and Verizon High Speed, I’ve come to find that Hughesnet is the ISP in the building. If you are in the area, who is your ISP and what is your street? I will be on 56th.
s1234
in About Brooklyn 10 years and 9 months ago
anotherposter | 10 years and 9 months ago
object(WP_User)#5387 (8) {
  object(stdClass)#5375 (12) {
    string(5) "53767"
    string(13) "anotherposter"
  int(53767)
This was a horrible lie they told you. Good luck finding decent service–surely in such a densely populated part of Brooklyn, you’ll find something that works for you. My folks live in the boonies and can only get internet and tv through satellites. For internet they have had Hughesnet for years and not only is it poor service, they are a horrible company. The data usage caps are stupid because it’s not based on actual use. My folks can have the computer turned off for days a when they turn it on, it might say they’ve used 30% of the daily allowance over the last several hours. That’s just one example. We can’t even send them links to videos or image heavy sites because it’s so slow and that will kill their usage for the day.
BobMarvin | 10 years and 9 months ago
object(WP_User)#5386 (8) {
  object(stdClass)#5385 (12) {
WHOOPS never WIRED, Not “never were” “
object(WP_User)#5388 (8) {
  object(stdClass)#5389 (12) {
“I thought every address in Brooklyn was serviced by one or the other” Not quite; although Cablevision has the franchise they’re never were most of Lefferts Manor, were I live. I had DSL for years, but it was slow, unreliable, and difficult to get Verizon to repair. A couple of years ago when it went out I switched to an AT&T MiFi device, which, while far from perfect, Is much better than DSL and (probably) Hughesnet. Whatever cell phone provider you use must have some thing comparable. Inferior to cable, but adequate were there’s no cable available.
shahnandersen
object(WP_User)#141726 (8) {
  object(stdClass)#5398 (12) {
    string(1) "6"
    string(13) "shahnandersen"
  int(6)
Agreed, Verizon DSL should be available anyplace that FIOS is not.
object(WP_User)#141728 (8) {
  object(stdClass)#141729 (12) {
    string(5) "53767"
  int(53767)
Hughesnet is Satellite based and probably the worst option in the US. Have you also checked with Cablevision? I thought every address in Brooklyn was serviced by one or the other, but they never service the same address. Surely you can Verizon DSL if neither cable company is there.
Arkady | 10 years and 9 months ago
object(WP_User)#141727 (8) {
  object(stdClass)#141730 (12) {
What’s your phone service? I’d think you could piggyback ISP on that.
dorkofwindsor | 10 years and 9 months ago
object(WP_User)#141729 (8) {
  object(stdClass)#141726 (12) {
quite a downshift – I couldn’t do it. hughsnet has serious data caps, slow speeds and astronomical prices. massive ping times prevent realtime anything, its mostly used in rural communities as an alternative to dial up. you can’t for example connect with VPN (roughly at dial up speed), do online games or trade from your computer etc. many users have problems with netflix. and if you enter a contract there are big pentaties if canceled. In short, i have not had it nor would i even consider it. I’d break my lease – and in 2015 this is not an insignificant amenity. What if you need it for work? I wonder why your building can not get TWC or Fios?
