Sash Replacements or Brick to Brick Replacements
We need to replace windows in our landmark house. Trying to determine if we should get sash replacement kits , or a full brick to brick replacement. Im looking at both options from Kolbe and I wonder about the cost of replacing the full unit and the labor/mess/disruption of interior moulding with full replacement. Advice and past experience shared greatly appreciated.
xistent
in Doors & Windows 14 years and 7 months ago
riis10 | 14 years and 7 months ago
object(WP_User)#5144 (8) {
object(stdClass)#5132 (12) {
string(5) "14773"
string(6) "riis10"
string(34) "$P$B4aUOCcSVKj5Gp0CJ2VbTXsJR69uua1"
string(6) "riis10"
string(20) "scooper1@fastmail.fm"
string(21) "/forums/users/riis10/"
string(19) "2017-08-10 14:01:31"
string(6) "riis10"
int(14773)
Would just suggest getting the most energy efficient ones you can, ie, triple pane and someone who understands insulation around the frames welll, while you are at it, since it’s all so expensive. Triple pane are still rare here, common elsewhere (CA and Eur) and the new standard here in a few years, and they make a remarkable difference re: sound and heat. I opted for the maximum light (glass) possible and maximum insulation, as I liked the idea that windows can be as insulating as walls. Best of luck – windows are so confusing, and it’s hard to forward-thinking, neutral info.
daveinbedstuy | 14 years and 7 months ago
object(WP_User)#5143 (8) {
object(stdClass)#5142 (12) {
OK, I read this wrong. I was thinking of the difference between inset replacements vs. full cased windows. Sash is different altogether and I think it will require an even better carpenter to do this job correctly without leaking. Look into inset replacement costs too. They are likely to wind up being more energy efficient and that makes a HUGE difference for heating bills
xistent | 14 years and 7 months ago
object(WP_User)#5139 (8) {
object(stdClass)#5145 (12) {
string(6) "157032"
string(7) "xistent"
string(34) "$P$BRLbZyzAMxkdkyDyHSTHkPT60a1PK90"
string(7) "xistent"
string(14) "xistent@me.com"
string(22) "/forums/users/xistent/"
string(7) "xistent"
int(157032)
these seem to be original windows. They are very old weight & chain pine windows. Why would sash replacement decrease window size? Taking out one sash and replacing using only a new jambliner should maintain the window size?? STEVE- do you have contact info who specializes in sash replacement. Thanks
object(stdClass)#5146 (12) {
I’m doing this with some upstairs windows in Bucks County. i believe we are using Andersons, true divided light, thermal pane. One of the issues that came up is that the all-wood ones were significantly thicker than the ones where the outside was aluminum clad…don’t know why. Anyway, the brown clad matches what the other ones are anyway. Have not had them installed yet so can’t report. My contractor is an excellent carpenter and I have no reservations thathe’ll be able to make the trim look right.
dazednconfused2 | 14 years and 7 months ago
object(WP_User)#5145 (8) {
object(stdClass)#5143 (12) {
string(6) "209624"
string(15) "dazednconfused2"
int(209624)
We’re looking into doing sash replacement in a landmarked brownstone because the window conditions are so unique that getting a full unit would cost a fortune. It doesn’t need to mean losing any window are as the sashes themselves are taken out, modified and put back into the existing frames. It’s labor intensive, but in a case like ours, it could end up cheaper than going the full route. Either way, you’ll need landmarks approval.
jockdeboeraia | 14 years and 7 months ago
object(WP_User)#5146 (8) {
object(stdClass)#5139 (12) {
string(5) "40876"
string(13) "jockdeboeraia"
int(40876)
If you can afford it and save the moldings for reuse (if they are good) do a full replacement. You are going to lose inches of window otherwise. Are these original windows?
stevecym | 14 years and 7 months ago
object(stdClass)#5147 (12) {
A customer of mine, who had been considering having me make sashes for her, went ahead with an outfit that specializes in sash replacement. I have to say, I was quite impressed with what I saw in terms of the quality of the wood work and also with how they fit in a landmarked building. I would recommend sash replacement if it can be done. Steve
