Recs for Iron Doors in Landmarked Brownstone?
Hey ‘Stoners, Does anyone have a good and reasonably price rec for a company to install a new iron gate/door in a landmarked brownstone? I’m replacing the gate that is under the stoop leading inside of the garden level floor. Any general prices on how much these doors cost? Thanks a lot
bk_bstoner1
in Doors & Windows 11 years and 9 months ago
HouseNut | 11 years and 8 months ago
object(WP_User)#5126 (8) {
object(stdClass)#5114 (12) {
string(5) "45965"
string(8) "HouseNut"
string(34) "$P$BhfkFH3s4gG9kG.gygxNT9BfagYY5p1"
string(8) "housenut"
string(23) "jsw_polemic@hotmail.com"
string(23) "/forums/users/housenut/"
int(45965)
I used Vinnie’s Iron Works on Bergen. We were quoted three options for a gate for under our stoop: $2500 for a new gate with a historic design but minimal details, $2500 for a refurbished vintage gate with the detail we wanted, and $3400 for a new gate with the detail we wanted. We chose the vintage gate.
allans | 11 years and 8 months ago
object(WP_User)#5125 (8) {
object(stdClass)#5124 (12) {
string(5) "27109"
string(6) "allans"
string(34) "$P$BWfuMxSA1DD7xfjcKR.qJ1ocmVh4cH1"
string(6) "allans"
string(21) "allansuarez@gmail.com"
string(47) "http://www.brownstoner.com/forums/users/allans/"
string(19) "2009-03-13 01:21:16"
string(6) "allans"
int(27109)
I had mine replaced as well, was not landmark or ornate – mine was plain (straight bar) no real details, the cost was $1900\. If yours is ornate and has design features that must be replicated due to **landmark** then cost will be more, plus keep in mind you may also need to get drawings done prior to fabrication. I used **ARC Steelworks** (Ramiro). They do beautiful **ornamental steelwork**, will probably use them again to fix parts of my front **brownstone fence**. Good Luck, Allan S.
bk_bstoner1 | 11 years and 9 months ago
object(WP_User)#5121 (8) {
object(stdClass)#5127 (12) {
string(6) "176992"
string(11) "bk_bstoner1"
string(34) "$P$BELpKe8aYkfQ5omh2n6KyB6uiTT5231"
string(21) "lyndora78@hotmail.com"
string(26) "/forums/users/bk_bstoner1/"
string(19) "2017-08-10 14:25:54"
int(176992)
thanks arkady. i will look into the location that you’ve mentioned
Arkady | 11 years and 9 months ago
object(stdClass)#5128 (12) {
Have you looked at the place behind Lowe’s on 9th St? I think I’ve seen gates there. Even if it needs a lot of work it might be cheapest way to go.
object(WP_User)#5127 (8) {
object(stdClass)#5125 (12) {
string(6) "176992"
int(176992)
thank you. i’ll check out the rec from metalwork. resident2: the metal gate was removed prior to landmarking. the wooden replacement door that was present at the time of landmarking is shot and i know that i can’t replace it w/another wooden one.
sunbury | 11 years and 9 months ago
object(stdClass)#5129 (12) {
string(6) "176862"
string(7) "sunbury"
string(63) "$wp$2y$10$NNReKusVUcNN4Ex/lvm8NOhJ39brTfVMYSNd3ggNteUFDPLFZMysu"
string(7) "sunbury"
string(19) "KellyK437@yahoo.com"
string(22) "/forums/users/sunbury/"
string(7) "sunbury"
int(176862)
I am also looking for someone to repair/replace mine. Years ago I was broken into. The culprits managed to warp the heavy metal and eventually lifted the gate because there were bolts were not in place. I will give them marks for determination! I am not in a landmarked building.
resident2 | 11 years and 9 months ago
object(stdClass)#5126 (12) {
It is generally best as far as Landmarks is concerned to repair/restore the existing gate. I have never heard of them approving a door.
