I need to replace one window in my Fort Greene brownstone.
I’ll say at the outset that although I would love to have old glass, alas, I am just a renter and the window that is broken was only ten+? years old and cheap itself. The entire top pane and frame popped out in the recent heavy winds. After years of wear and tear, I helped it die during cleaning this summer. I took it out then to clean it and it wouldn’t pop back in without heavy force. Any advice? My landlord may or may not cover it, and it has to be inexpensive. I want to be prepared. Thanks in advance!
marybrkln
in Doors & Windows 11 years and 11 months ago
8
avswindows | 11 years and 10 months ago
object(WP_User)#5028 (8) {
object(stdClass)#5016 (12) {
string(6) "181309"
string(10) "avswindows"
string(34) "$P$BvTVjwnt9IPEzv8cthCAcBWga6Vp0B."
string(20) "avswindows@yahoo.com"
string(19) "2017-08-10 13:44:19"
int(181309)
AVS Windows is best place to replace windows.
metalwork | 11 years and 11 months ago
object(WP_User)#5027 (8) {
object(stdClass)#5026 (12) {
string(6) "181255"
string(9) "metalwork"
int(181255)
Core Solutions we specialize in dealing with historic metal work on Brownstones. reasonable prices. I have a question, is this a landmark building? Also, feel free to check out our mini site on here, under the metalwork section, you can see pics of our work.
NeoGrec | 11 years and 11 months ago
object(WP_User)#5023 (8) {
object(stdClass)#5029 (12) {
string(4) "1741"
string(7) "NeoGrec"
string(7) "neogrec"
string(7) "NeoGrec"
int(1741)
Try Mega Glass on 5th Ave @ Bergen. They can be grumpy but they know their stuff and they are not expensive.
no-permits | 11 years and 11 months ago
object(stdClass)#5030 (12) {
string(6) "176811"
string(10) "no-permits"
string(16) "c90027@gmail.com"
int(176811)
“my brownstone” you must be rent stablized because a market rate tenant wouldn’t talk like that.
marybrkln | 11 years and 11 months ago
object(stdClass)#5031 (12) {
string(5) "18777"
string(9) "marybrkln"
string(34) "$P$BmEv6ejur1fGKztzVVrPk/kaPiMfQ80"
string(24) "christine.krol@gmail.com"
string(19) "2017-08-10 13:44:15"
int(18777)
Thanks so much, all. This is all helpful.
daveinbedstuy | 11 years and 11 months ago
object(stdClass)#5032 (12) {
I have used Vila and highly recommend them. they will come up with a solution that won’t be expensive
ventilated | 11 years and 11 months ago
object(WP_User)#5031 (8) {
object(stdClass)#5028 (12) {
string(6) "176829"
string(10) "ventilated"
int(176829)
I was going to say something similar to bedstuyreno. Cheap replacement windows are known for warping and distortion. You took the window out to clean (a level of maintenance most LLs would appreciate). That it was hard to pop back in frame was most likely an indication of already existing warp. You certainly are not responsible for effect of high winds. Though I have not used either of these vendors, I’ve seen both recommended on this forum: http://www.vilawindowrepair.com/index.html http://www.sebuilding.com/
bedstuyreno | 11 years and 11 months ago
object(stdClass)#5033 (12) {
string(6) "180648"
string(11) "bedstuyreno"
string(34) "$P$BLPX/K0nYfMbhZHudsdksxbr7paWYh."
string(18) "kvharper@gmail.com"
string(19) "2017-08-10 14:06:34"
int(180648)
array(121) {
Your landlord is required to cover this- granted that you didn’t break the window by carelessness. If he/she refuses to pay send a letter stating that you will pay for the window and deduct it from the rent.
