Fixing Wood Framed (Original) Windows on a Budget
We’re just finishing up the interior renovations on our brownstone and due to budget restrictions we were only able to replace the windows in the rear facade of the building. The windows in our front facade are the original double-hung variety and are more than a little worse for wear. We have 7 int total to repair, with a combination of cracked/broken panes, windows that won’t open, windows that will open but immediately drop etc. We really aren’t in a position to replace them or have them properly restored right now, but I’m hoping to get them safe and functional again. Looking at previous forum posts, it looks like Vila Window Repair would be a good company to contact. Does anyone else know of a company that is happy to take on super old wood windows? If anyone has had similar work done can you give me a ball park figure on what your work cost? All help/advice appreciated!
concerned100
in Doors & Windows 10 years and 2 months ago
concernedcitizen | 10 years and 1 month ago
object(WP_User)#5112 (8) {
object(stdClass)#5056 (12) {
string(6) "177166"
string(16) "concernedcitizen"
string(34) "$P$BLl2eR52NXq8qq.ofKXYiMri5WqO9j0"
string(27) "peter@methodrestoration.com"
string(32) "http://www.methodrestoration.com"
string(19) "2017-08-10 14:25:59"
string(18) "Method Restoration"
int(177166)
We specialize in restoring landmark windows. It is a labor intensive process and unlike some believe, requires a fair amount of skill to do properly. I would advise to try to live with the current situation until your budget allows you to repair them properly. I have had to rerepair (when possible) many prior attempts at restoration.
derbynyc | 10 years and 2 months ago
object(WP_User)#5111 (8) {
object(stdClass)#5110 (12) {
string(6) "195459"
string(8) "derbynyc"
string(34) "$P$BFw4.paYi.X/Kp8TNDlKsDAA2YZyS0."
string(26) "chrismitchellnyc@yahoo.com"
string(19) "2024-04-18 19:50:03"
int(195459)
I can recommend you to look for such companies here as well: https://goo.gl/7v5j8c They can provide you with any window service you need at affordable prices.
catboot | 10 years and 2 months ago
object(WP_User)#5107 (8) {
object(stdClass)#5113 (12) {
string(5) "56593"
string(7) "catboot"
string(7) "catboot"
string(7) "catboot"
int(56593)
I believe Daniel over at Manhattan-nest.com has a tutorial on window fixing as well. I wish we still had our old windows. The previous owner replied them with cheap, ill fitting vinyl windows sometime in the 90s… sigh.
cate | 10 years and 2 months ago
object(stdClass)#5114 (12) {
Just FYI, any carpenter can handle this job. Also there are numerous books and info online available on the topic, if you want to understand what needs to be done. Google DoorSixteen window repair, Working Windows, etc. It’s preferable to do what you are doing and keep them rather than replace — more energy efficient, better looking, less expensive, and less wasteful. Good luck.
santos | 10 years and 2 months ago
object(WP_User)#5115 (8) {
object(stdClass)#5116 (12) {
string(6) "184684"
string(6) "santos"
string(34) "$P$BN.47ngcxat9CJqHXFyNmSTH4Exrkv/"
string(6) "santos"
string(23) "pliniosanto25@gmail.com"
string(19) "2017-08-10 13:57:22"
string(6) "santos"
int(184684)
Hi my name is santos, I’m carpenter work in wood, install stair, railings, pocket door and Repair of interior stairs, floor repair , Install crown molding, base, door trim and door replacement. New window and new entry door installation Siding installation My number is (347) 701 0635 …pliniosanto25@gmail.com
xchx | 10 years and 2 months ago
object(WP_User)#5117 (8) {
object(stdClass)#5118 (12) {
string(6) "176790"
string(4) "xchx"
string(4) "xchx"
string(16) "zdfaux@gmail.com"
string(4) "xchx"
int(176790)
I got an estimate from Vila once and they wanted a couple hundred dollars per window to fix them. At that price I figured I was better off saving for new ones. Your experience may vary.
