Energy Efficient Windows - Cost and Timeframe?
I’m looking to replace two windows, approximately 30″ by 96″, with energy efficient ones. How much am I looking at for parts and labor? How long should I expect the work to take? Thanks.
DouglasAlan
in Doors & Windows 13 years and 5 months ago
stevenjames | 11 years and 5 months ago
object(WP_User)#5061 (8) {
object(stdClass)#5115 (12) {
string(6) "182775"
string(11) "stevenjames"
string(34) "$P$BOgrTlAFN7ri4yhFFw5f0PRrIcTWuq1"
string(22) "james2steven@gmail.com"
string(19) "2017-08-10 13:54:19"
int(182775)
Energy Efficient Windows typically costs about 15% more than ordinary glass, but it reduces energy use by as much as 30-50%, by using most of the heat gain in winter but keep the harmful UV rays out during the summer, and when used in insulated glass units – can have even better benefits.
cate | 13 years and 5 months ago
object(WP_User)#5062 (8) {
object(stdClass)#5063 (12) {
Or could be about $4,000 installed if you are using wood Marvins (we got a quote for $30,000 for 15 of these). It will take less than a day to install two windows.
object(WP_User)#5060 (8) {
object(stdClass)#5059 (12) {
If you are lucky enough to have original windows, you can make them more energy efficient than replacement windows with maintenance and storms. There are a lot of disadvantages to replacement windows, which unfortunately we have: They are very expensive, they don’t last long, and they sit inside a frame inside a frame so they look unattractive and reduce the size of the window glass and the amount of light and view.
berniceshola | 13 years and 5 months ago
object(WP_User)#5067 (8) {
object(stdClass)#5058 (12) {
string(6) "209445"
string(12) "berniceshola"
string(63) "$wp$2y$10$gwDmwyYYyzH/pPO3w5IQLeFbET/qg5Uvdf5jZstpNefVx8uCfGm/G"
string(33) "c.r.ystal.nel.s.on.3445@gmail.com"
string(19) "2024-06-29 07:24:25"
int(209445)
$1500-2000, depending on windows you choose, and it’ll take half a day.
