Brick to brick windows - interior
Hi, looking for information on what basic interior looks like after a brick to brick install. We are removing the historic moldings for replacement after but its not clear what the window surround behind where the moldings currently are will look like. I’m assuming we’ll be left with some gaps to fill where the old sash lifts were located. Does anyone have photos from during/after an install? Thanks, Susan
orrsuz
in Doors & Windows 9 years and 11 months ago
SimpleTwig | 9 years and 11 months ago
object(WP_User)#5043 (8) {
object(stdClass)#5089 (12) {
string(6) "161782"
string(10) "SimpleTwig"
string(10) "simpletwig"
string(51) "http://www.brownstoner.com/forums/users/simpletwig/"
int(161782)
Hi @orrsuz, Are you saying you want new windows with no interior walls, but to just leave the exterior wall as exposed brick?
Assuming you have a typical Brooklyn brick townhouse, the inside brick will be wider by 4 inches than the exterior.
I would suggest using this recess to secure studs to the brick building it out so the window can have brick molding on the exterior, insulating all around the framing and window, and then secure the window to the stud(s). With the window and studs in place you can then add trim.
If on the other hand you push the windows outward towards the facade you might be able to secure them directly to the brick, but you’ll have to ensure the jamb of the window works with the depth of the brick layers (brick townhouse vary from 8″ typical up to 16″). If you do that, don’t forget to incorporate the Energy Conservation Code regarding insulation requirements into your design 🙂 Good luck.
lynnepoling | 9 years and 11 months ago
object(WP_User)#5042 (8) {
object(stdClass)#5041 (12) {
string(6) "193604"
string(11) "lynnepoling"
int(193604)
not the best of photos due to the bad lighting .
Assuming that it’s old weight & chain wood Windows.
You have a weight pocket of about 3″ on either side that would need to be filled.
keeping the old casing is tricky as the new Windows must be custom sized to the 1/8″ or they won’t fit.
If the Window frames/Box are still in good shape look into Pocket Windows which are full new Windows with a 3.5″ jamb and get installed into the existing frame.
cate | 9 years and 11 months ago
object(WP_User)#5038 (8) {
object(stdClass)#5044 (12) {
This Brownstoner post on window replacement shows the inside of the window with the window gone. The interior molding is still attached, however, so it doesn’t show what’s under there. http://www.brownstoner.com/interiors-renovation/photo-pool-challenge-replacement-windows/
