Best window option for landmarked building
How would the community differentiate between the LPC-approved replacement window options? Thinking about cost, efficiency, durability, and aestetics, where is the best value (and why)? I was told that the LPC is now approving a wood-look or a painted metal window, but have no details. Has anyone heard about this? Thanks as always….
housepoor
in Doors & Windows 14 years and 3 months ago
bostudio | 14 years and 3 months ago
object(WP_User)#5062 (8) {
  object(stdClass)#5115 (12) {
    string(6) "178408"
    string(8) "bostudio"
    string(34) "$P$B404abr1XIMtSmBGvG5f9nNz.Ez8Jt1"
    string(20) "ubochinska@gmail.com"
    string(49) "http://www.brownstoner.com/forums/users/bostudio/"
    string(19) "2017-08-10 14:19:50"
  int(178408)
I have gotten approval for aluminum windows in the rear of the building (not visible to the street).  In the front you will need to find a profile that matches as closely as possible to the profile of the historic window.  Your choices will depend on that.  I would look into Kolbe & Kolbe to start. Ula Bochinska, www.bostudio.us
housepoor | 14 years and 3 months ago
object(WP_User)#5063 (8) {
  object(stdClass)#5064 (12) {
    string(5) "71781"
    string(9) "housepoor"
  int(71781)
OP here. How would you compare the different LPC allowable windows available on the market — looking at cost, efficiency, durability, and aestetics. Which is better in any particular area? Is there one brand which stands out? Thanks.
dazednconfused2 | 14 years and 3 months ago
object(WP_User)#5067 (8) {
  object(stdClass)#5061 (12) {
    string(6) "209624"
    string(15) "dazednconfused2"
  int(209624)
We do a lot of window replacement with landmarks.  I have never heard of them allowing the installation of anything other than wood windows, with the rare exception of a more modern building that happens to have been within a historic district when the district was created.   If aluminum windows were present when it was designated you might be able to replace them in kind.  You can maintain existing aluminum windows,even  paint them to match the prevailing original colors, but you cannot replace old wood with new metal.
clickandimprove | 14 years and 3 months ago
object(WP_User)#5064 (8) {
  object(stdClass)#5062 (12) {
    string(6) "179156"
    string(15) "clickandimprove"
    string(34) "$P$BoPUrBkb6Iqej8tYo8atQ9FKqUKaai/"
    string(27) "anthony@clickandimprove.com"
    string(30) "/forums/users/clickandimprove/"
    string(19) "2017-08-10 14:39:07"
  int(179156)
LPC does allow for changes to windows for replacement and repair. Generally the most important aspect of windows to be prepserved is visible configuration, as in the shape of the window and number of panes. Windows with decorative divisions are often permitted if they appear in proper configuration. I have a PDF check list that you may find to be helpful….email me at anthony@clickandimprove.com and write LPC Checklist Request in the subject….I will shoot it off to you. I do a lot of research for our clients. Some things I have and don’t. If it does not serve….all you wasted was bad read time. Knowledge is power.
