Steam Heating
This is my first time posting. The radiators get hot in the front of the house but not in the rear. The risers do get hot though. Have changed valves and pitched radiators. Can someone recommend a heating expert. The house is 4 floors + cellar. Thanks.hansen1
hansen1
in Plumbers and Plumbing 12 years and 4 months ago
angelhudson | 11 years and 3 months ago
object(WP_User)#5090 (8) {
object(stdClass)#5135 (12) {
string(6) "184949"
string(11) "angelhudson"
string(34) "$P$BOLLLPmPwoimALFGMOB.iO4hL72J/x0"
string(26) "angelhudson123@outlook.com"
string(19) "2017-08-10 13:55:28"
int(184949)
I think that, It is a radiators leakage problem but I am not sure. So you should hire any heating company like [heating repairs nj](http://allweekheating.com/ “heating repairs nj”). They can give you better suggestion on it.
johnv00 | 11 years and 9 months ago
object(WP_User)#5091 (8) {
object(stdClass)#5092 (12) {
string(6) "182499"
string(7) "johnv00"
string(34) "$P$BoXAqO20EuW8P4gTjkAs0hDd90/UbB."
string(7) "johnv00"
string(21) "vodkajohn51@gmail.com"
string(35) "http://www.averyhomeremodeling.com/"
string(19) "2017-08-10 13:49:14"
string(7) "johnv00"
int(182499)
I was having the same problem with hansen 1 recently. t’was hard for a homeowner without any knowledge about it. Good thing a guy from [Florida Air Care](http://www.flaaircare.com/) helped me solve the problem.
steam_man | 12 years and 4 months ago
object(WP_User)#5095 (8) {
object(stdClass)#5089 (12) {
string(6) "176846"
string(9) "steam_man"
int(176846)
MP..I just love this. Same approach I’ve been taking with people from Brownstoner who contact me. It feels much more rewarding. Merry Christmas sir. -S.
eman134 | 12 years and 4 months ago
object(stdClass)#5088 (12) {
Is it the end of the house that is farthest from the boiler that is old?….then you need to replace and /or resize the master vent at the base of the riser. However some houses never had a master vent in the first place ,at which point you need someone (like myself) to drill and tap a takeoff for the vent or vents.My contact info is in my profile, so feel free to contact me
Master Plvmber | 12 years and 4 months ago
object(stdClass)#5087 (12) {
The things that stop the flow of steam heat are limited: 1\. trapped air – fix/replace your air vent. 2\. trapped water – pitch your horizontal piping and radiators properly 3\. mechanical closure – open the closed valve 4\. insufficient steam supply – your boiler’s too small or it’s busted 5\. early condensing – insulate pipes running through cold areas 6 sediment blockage – it never really happens but everyone thinks this is what’s wrong Start there and see if you still need to call someone. http://brownstoner.staging.wpengine.com/gatewayplumbing
