NYC Code - Plumbing Handles
http://cdn.brownstoner.com/4faa9596c4d3a-.jpg
Hey all, Plumber says that these handles are no longer code in NYC. He replaced them in the cellar during the pipe replacements, but left them on the water control valves in the bathrooms. Are they OK in the bathrooms then? Thanks, SWR
SewardWasRight
in Plumbers and Plumbing 13 years and 11 months ago
12
ivanster | 12 years and 4 months ago
object(WP_User)#5051 (8) {
  object(stdClass)#5088 (12) {
    string(6) "181096"
    string(8) "ivanster"
    string(34) "$P$B/B.E.g9WBOsMwWH/.eM1MYqPZWx.61"
    string(21) "dannyrevera@gmail.com"
    string(19) "2017-08-10 13:44:12"
  int(181096)
If you want to get [solar and gas geysers installed](http://www.plumbers-johannesburg.com/geyser-repair-installers/) by the professional plumbing services at Johannesburg, you should make sure that they have rich experience in handling such jobs.
object(WP_User)#5077 (8) {
  object(stdClass)#5078 (12) {
    string(6) "181096"
  int(181096)
Well, I think, the lever shaped handles are better than these round handles, as they are easy to handle and there are lower chances of water leakage. Thanks! [San Diego landscape contractor](http://www.sandiegolawncareservices.com/landscape-design)
mikj | 12 years and 4 months ago
object(WP_User)#5081 (8) {
  object(stdClass)#5056 (12) {
    string(6) "181067"
    string(4) "mikj"
    string(34) "$P$BEfLdfpbD0ZzPRiFB/0BLn74TAvYQ20"
    string(4) "mikj"
    string(26) "saranwilliams591@yahoo.com"
    string(19) "2017-08-10 13:44:11"
    string(4) "mikj"
  int(181067)
Recently, I got the [solar and gas geysers installed](//www.plumbers-johannesburg.com/geyser-repair-installers/”) by the professional plumbing services at Johannesburg, and they did their job up to my satisfaction.
wholesalerbill1 | 13 years and 11 months ago
object(WP_User)#5078 (8) {
  object(stdClass)#5051 (12) {
    string(6) "178980"
    string(15) "wholesalerbill1"
    string(34) "$P$BWqWbpzPIaV.nbW7YDTL0bM6rRNc9c."
    string(17) "gwazzoo@gmail.com"
    string(30) "/forums/users/wholesalerbill1/"
  int(178980)
Run Forrest Run!!!!!!
SewardWasRight | 13 years and 11 months ago
  object(stdClass)#5057 (12) {
    string(5) "52609"
    string(14) "SewardWasRight"
    string(7) "usgrant"
    string(7) "USGrant"
  int(52609)
The plumber told me that in order to remove the oil tank he would need a special kind of hammer called a water hammer, and he had to special order it. It took 3 weeks to arrive!
  object(stdClass)#5058 (12) {
    string(6) "178980"
  int(178980)
Egads, you didn’t question that? What can I sell you that you don’t need?
object(WP_User)#5057 (8) {
    string(5) "52609"
    string(7) "usgrant"
    string(7) "USGrant"
  int(52609)
So, I probably didn’t have to have a new oil tank installed in the basement because black paint is no longer authorized as an oil tank color?
object(WP_User)#5058 (8) {
  object(stdClass)#5077 (12) {
    string(6) "178980"
  int(178980)
Can you say Bamboozled?
no-permits | 13 years and 11 months ago
  object(stdClass)#5081 (12) {
    string(6) "176811"
    string(10) "no-permits"
    string(16) "c90027@gmail.com"
  int(176811)
that plumber saw you coming.
Master Plvmber | 13 years and 11 months ago
There is no code pertaining to types of valve handles.
Bklnite | 13 years and 11 months ago
  object(stdClass)#5059 (12) {
    string(4) "7850"
    string(7) "Bklnite"
    string(7) "bklnite"
    string(7) "Bklnite"
  int(7850)
… if the valves in the bathrooms are OK (and you’re not renovating) then I’d just leave them alone.
  object(stdClass)#5060 (12) {
    string(4) "7850"
    string(7) "Bklnite"
    string(7) "bklnite"
    string(7) "Bklnite"
  int(7850)
I don’t know the code, but if you’re replacing valves or have any doubt about whether an old gate valve (like the one in your picture) is working right you’re better off putting in a ball valve.
data:image/jpeg;base64,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
Gate valves can get stuck and stay open or closed regardless of which way you turn the knob. http://www.pro-handyman.com/home-repair-articles/ball-valves-vs-gate-valves/
